  • Replies 1k
Posted Images
I'll PM when the car is off life support...
rods pistons n head studs got here today. WIN! 4 days or so from the states (not including weekend)
Phil - Did my email come through last night?? not sure if it sent properly, might of done it twice in fact
Edited by Force Fed
Yeah man got it. Will hopefully let you know some info in the next couple of days.
Glad to hear your getting a bike Phil. Will definitly have to go for a ride when you get it.
Yeah I miss not having a bike. Very much looking forward to the R6 :)
What is peoples take on this, just got this done 20 mins ago.
The dyno operator mentioned that its running rich, I had an inclination towards this, but wanted to confirm my suspicions. Leaving flame work everywhere was a good indicator though.
What do the standard RB25 run as far as AFR levels?
Main question really, is it reasonably safe?
Car is running 10psi of boost.
is that on stock ECU?
10.5:1 is pretty rich, mine ran about 10:1 on stock ECU back in the day
around 12:1 is what you want (in short, its not as simple as 12:1 everywhere, but roughly that)
Its a good result if your running stock ECU, I made 141rwkw on 8psi with the stock ECU, hit R&R real bad on anything above that
Nah running Power FC
The dyno operator didn't sound keen about it being so rich and suggested a tune.....to the tune of $600
How 'un-safe' is it to be running as rich as this? Or is he just trying his charm on me?
Eventually I do want to run around the 12-14psi mark, already got a walbro, but first got to save up for the injectors.
Don't run 12-14psi through the stock RB25 turbo (It's the stock turbo yeah?) or you will blow out the exhaust wheel into the cat. Especially with it coming into summer.
If it is the stock turbo you don't need injectors at this stage.
That AFR on a Power FC definetely needs a tune.
I ran 12psi on stock turbo for over a year without any issues, but I know others that havent been so lucky, I'd stick to 11psi.
Its not un-safe to be running 10.5:1 AFR's, quite the opposite really (unless hes checked a bunch of timing at it)
See where your power starts to drop and notice that its also where your AFR jumps to 10.5:1 This is where you will be losing your peak power unless you have exhaust/intake restrictions or some other kind of issue. How does the plot for your boost look? (If they gave you a power vs boost graph)
If not and you want to know, the dyno run should be stored in there dynos computer and you will be able to go back and get them to print one out (assuming the plotted the boost, which they should have)
luck of the draw on turbo's but it's a timebomb IMO :)
Yep, stupidly rich. I'd almost say too rich, it would want to flood the chambers a bit.
Nice power though!!!
Keen as f**ken mustard to see the results of yesterday!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Edited by Force Fed
Nope unfortunately not. Have decided I shall be parting my car out (have allready began selling one or two things). At this point in time the money invested into that car can be better used so it has to be done. Never thought this day would come to be honest lol.
And yes Chris, you can have my title :P
:O
don't do it phil, you'll regret it.
:O
I'll be sad to see it go. But gotta move on. House is the priority at the moment.
Robbo's right Phil you will regret it and you'll never make your money back.
Nah definetely won't make it back. However should get a decent amount back by parting it out. I've calculated what I should roughly get back in the parts that I have put onto it alone and it's a decent amount.
Parting out can make quite a lot back, I've done it before.... Time will tell :)
Phil - Carbon A Pillar + 2x52mm gauge pods able to get em?
The carbon A pillars might get ruined trying to take them off?
    • The title should have posted "EFR7670 exhaust housing selection RB26" I can seem to edit thr title on my Android.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
