got my set up dynoed yesterday and had a few issues... mainly the good old missfires and then the gate decided to stay stuck open, pulled it apart and cleaned it out and was ok after that.
however its painfully slow to build boost and the boost graph looks like a gradual slope instead of ramping up and staying there. Im running a bleed valve on there atm and im led to believe that an EBC should be the way to go.
however we tested the spring from the HKS gate and its only a 0.6 bar item... not quite the 1 bar one i thought it was. So its quite soft and i dont think that a ebc will cope with running over double the rated spring pressure.
if i got a 1 bar spring, will it ramp up harder? considering the spring is slowly opening now as it builds boost i reckon it will.
target boost is around 1.1 - 1.2 bar
take the vac line off the gate and see when it hits the boost you want, back off as soon as it does tho. if the boost graphs looks good like that then you need a better boost controller, if its still no good then try a firmer spring. i find the profec b good for this stuff, as you can set exactly what boost it allows the gate to see any boost at all, meaning you can keep 0 pressure at the gate all the way up to 1bar if you want.
with good boost control you shouldnt have any trouble running double the rated spring pressure, its far from ideal but it works. i'm holding 22psi perfectly with a 12psi actuator and a profec b
Edited by JonnoHR31
If you put a 1bar spring in there, it will ramp up much harder.
With a 0.6 Bar spring you are more than likely getting gate creep.
I ran 24psi, external gate with a 16psi spring and bleed valve for the other 8psi - worked fine.
However when i was running 14psi using a 7psi spring, i would get massive gate creep even though i was bleeding less.
So without question, you will benefit from a heavier spring. Less work any boost control/valve has to do, the better.
If you want to run 1bar, stick a 1bar spring in there :worship:
next question is where do i get a spring from to suit a HKS gate? cant find any on the usual import sites.
Sell it, very old outdated technology and you can find better 48mm / 50mm external wastegates locally.
The new Turbosmart 50mm is the goods, or the GFB.
If you want something cheaper get a Tial.
haha out dated lol.
yeh im in same dilemma turbo comes on slower then expected im running 1bar spring running 1.4bar boost
seems 2 build slow.. im running no boost controller though im just tightening the allen key screw on top of wastegate to hold it closed longer
any idea if the length of the vacum line can cause the slower boost building?
try get your spring from these guys http://www.redlineperformance.co.nz/?action=fitting they are in NZ. Daryl young is the guy to speak to. he helped me out with some springs for an old HKS 60mm gate. just get the part number from the HKS website (US or Jap) and give it to him, should be able to help you out
and yes good explanation, "its just a spring and diaphragm" ......... out dated haha???
like i said, go for a drive with the vac line removed. no point buying a heavier spring then having to get an ebc aswell when it doesnt solve your problem. yes it probably will, but test before you buy
HKS springs are colour coded, you will want a yellow one for 16psi, you've probably got a pale blue or white one now???
I'm with you guys, don't see how a WG can be outdated, they are a simple thing and most are all generally pretty much exactly the same except for the bling bling [blue anodising/chrome etc etc]. Spring, diaphragm, and poppet valve!!
Plus if you use SK's formula for WG size, most are too big for my and other gtst applications. I'm doing over 280rwkw and according to SK formula needed a 40mm ie HKS is 40mm. Not saying others don't work, and you can have your 38, 48 or 60mm or whatever, but for optimum efficiency etc its supposed to be 40mm.
I actually got some 1 bar and 1.8 springs made to suit HKS 50mm gates. If you want PM me your wastegate spring Dia. I might be able to help you out with a lot cheaper solution.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
