pull door trim, pull door catch, two 10mm bolts hold the handle on. thats it.
the little rod holders pop off by twisting the plastic clip then the rod slides off the latches. DO NOT CLOSE THE DOOR or LOCK them they can bind up and not open right again without some acrobatic stunts to get into the crevices of the door cavity. pain with seats in the car still.
  • 4 weeks later...
+1
  • 6 years later...
I've unbolted my handle and I'm trying to get it out but it's not cooperating. Should I just be a bit more rough with it?
Edited by MissR33gtst
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
