that looks pretty good. mmmmmm if only my car had the Dual sunroof....
jut note that they have fitted ARX wheels to the AXIS. Axis wheels are slightly different but still 18's as are the ARX.
Good luck.
Yeah I noticed that.
I am going to question them about it, but ultimately I'm not too concerned. I want to purchase a nicer set down the track anyway.
Thanks for the replies guys.
Hey Chris/Amanda, it's Eugene here.
You came and test drove our black ARX a few weekends back at Northshore Prestige. Although you guys liked the car, it was formerly owned by a smoker. Well we have just imported a very nice gold ARX Stagea which is almost identical to the black one you guys saw, only that there's no smoke :ninja:
If you are coming down to Sydney again, please drop by again if you have the time. Here's a link to some pics. It's on the 2nd page.
http://northshoreprestige.com.au/used.php
cheers
Eugene
You came and test drove our black ARX a few weekends back at Northshore Prestige. Although you guys liked the car, it was formerly owned by a smoker. Well we have just imported a very nice gold ARX Stagea which is almost identical to the black one you guys saw, only that there's no smoke :)
cheers
Eugene
Not bad Eugene, however I prefer the clearance issues I have with my RS ;) gotta love the Nismo S-Tune suspension, I can scrap the front aero kit on practically anything :)
Here's everything you need to know about these importers. Just read the last few pages and you will get a good idea..
http://www.evolutionoz.net/forums/index.php?showtopic=6853
Says link is dead or outdated :)
What sort of price range are you looking for?
Bloody smokers cars!!! :)
Yeah lol. It kills it, especially when its pretty intense.
You came and test drove our black ARX a few weekends back at Northshore Prestige. Although you guys liked the car, it was formerly owned by a smoker. Well we have just imported a very nice gold ARX Stagea which is almost identical to the black one you guys saw, only that there's no smoke ;)
cheers
Eugene
Hi Eugene.
Thanks for the info. We have been in contact with Ben, and he sent us through some photos yesterday I believe. It does look nice. We will be down Sydney way this weekend, so hopefully we will be able to make our way over there. We are useless driving in the city lol...
Thanks Again for your help and service.
Bloody smokers cars!!! :huh:
Ah forgot to answer question lol.
We are looking ate spending 23-24k. We have our wedding in May so we don't want to spend any more than that, as we have other moneys put aside.
Hopefully the cars we are looking at check out fine, as they suit what we are after and they come in under our budget.
Hopefully I can get a bit lower as they'll be getting the amount in cash.
Edited by 3PointJ
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
