www.justjap.com.au or similar check the trader section found near for sale...
get a kit and then either DIY or find a trusted installer...
dont know anyone on the sunny coast personally but there is RPM at Morayfield which is not far to drive...
https://www.sau.com.au/forums/topic/307073-front-mount/#findComment-5074205
AMAUTO can do anything.
at sunshine coast.
http://amauto.com.au/
don't worry about the subaru conversion..
he does those with his eyes closed.
he's put so many different motors in so many things it's silly.
latest is a 2jz in to a 67 crown.
give him a call and get a price.
you'll never go anywhere else.
I drive up from Brisbane for any work to be done.
https://www.sau.com.au/forums/topic/307073-front-mount/#findComment-5075236
at sunshine coast.
Hahaha i wouldnt touch these guys with a 10 foot poll (miles and Allan), leave your car there and you'll be told you have a stuffed engine,( not me but some people in know) then find out there was nothing wrong with the engine to which they resell to someone else and put another lucky dip engine in your car.Suggest you go have a look at some of there work and any other workshops work before going ahead with any work.
Marty at Mw performance is one of the best, 54455953,he is kunda park.
https://www.sau.com.au/forums/topic/307073-front-mount/#findComment-5075558
i've heard nothing but good from am auto..
a place where my r31 copue is atm, with getting front mount and cooler and lots work done, red roo in nambour.. or ultra tune.. is the sister shop
quality work there :D
https://www.sau.com.au/forums/topic/307073-front-mount/#findComment-5078204
Hey mate, If you have any ability with the tools save yourself some cash and fit one yourself. I bought a stealth kit from just jap and fit it pretty easily. Didn't take all that long either.
I'm in Landsborough so if you want some help give us a yell. What colour is the 33? I have most likely seen it around.
https://www.sau.com.au/forums/topic/307073-front-mount/#findComment-5079935
yeh sounds good man ive never installed one before so i was just gonna save myself the hassle but it would be good to give it a shot. its white atm, havent driven it in about 8 months so u wouldnt have seen it for a while im goin to pick it up in 10 weeks so around then i might give you a buzz and let u no!
cheers
https://www.sau.com.au/forums/topic/307073-front-mount/#findComment-5080976
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - there is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
