Have just purchased a Haltech R32/R33 Platinum Pro plug-in for my RB25 R32.
First off does anyone know what these retail for? Want to know if I got a good price...
Anyway, as I will be running the MAP sensor I'm assuming I have to now get an intake-air temp sensor?
Wondering if I need a Haltech ATS or if someone like Jaycar would sell something a lot cheaper that would do the same job?
The cost of everything lately is blowing out of control quick-smart so need to save money wherever possible...
If I do need the Haltech unit does anyone have an idea on price?
& I'm assuming the best place to mount this is just before the throttle-body so it is actually monitoring the temp of the air entering the plenum (after the intercooler, etc)
Another thing I am unsure of is with the Haltechs boost-control, do I need to purchase the Haltech boost-control solenoid or can the ECU control the factory R33 solenoid?
I am also wondering if I am able to rig up a switch to change between a high & low boost setting or if I am stuck on one setting?
If a switch set-up can be done how would you go about it?
Sorry for so many questions but I have very limited access to my tuner until next weekend when it is arranged to be tuned.
So obviously I need to have everything ready to go by then.
Any advice & info would be very helpful.
Cheers,
Brett
A bit over 2k i think they are.
Put the air temp sensor in the intercooler pipe before the throttle body.
IMO Haltech boost controllers are not the best. Profec B2 is the best you will ever use.
If you are going to use the Haltech one, you will buy it in a kit. Comes with solenoid and dial. The dial is used to increase or decrease boost, a bit old school but it works.
Cool, done alright then.
OK, but do I need the Haltech ATS or will a universal (jaycar, etc) one do the same job if I can find one cheaper?
Thanks for the opinion. Will probably buy a stand-alone EBC later but just want to get car running for now.
So is it possible to use standard R33 solenoid? & just not be able to adjust boost level from in car?
P.S Will be depositing money for brake pads on Monday
& if I can use the standard boost solenoid do I have to give it a constant earth like people do to eliminate the two-stage boost setting or will the Haltech automatically take care of that, keeping it on one boost setting throughout the rev-range?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
