ringwood auto spares in VIC (ebay store) he stocks all sorts of goodies at VERY good prices. (Rob Mills)
if i find a link to his store i will post it up
if you are upgrading your front swaybar to an R31 item you'll need the bushes to suit.
nolothane make good castor rod bushes too (made a heck of a differenxe on mine)
you can also get steering coupling bush too (looks like a cookie with 4 equally spaced concentric holes)
Thanks Andrew
I didn't know that.
I've changed virtually every other bush in my car and fitted front and rear Selby swaybars so she should be nice and tight when back on the road.
Thanks Andrew
I didn't know that.
The Wideline Sports (aka Noltec) steering coupling bush is VERY exy, but if you do a search on US Ebay you will find a guy called reddat and he sells just about everything you can think of for an 280ZX and his steering coupling is the same and half the price. And if you buy other things from him, the freight cost is shared across all items.
Cheers, D
I've ordered all the steering bushes thru wilkinsons. Where can I get more info on the r31 swap?? I was just going to get a selbys on the front and a custom thick one on the rear. Yes I realize the rear is a bit of work.
Unless you're prepared to spend a lot of your time replacing poly bushes, they are not necessarily the ants pants. I have replaced all the compression points with poly, but left the pivot points as OEM rubber bonded bushes, as most of the rally guys do. A greased poly bush when it flexes, elongates the hole the sleeve is in and dirt gets in, grinding away the hole size until it's stuffed and has to be replaced.
As for the front R31 sway bar, it's a straight swap, but 25mm D bushes need to be sourced, or buy the universal mount kit from Selby's. The Selby front sway bar kit uses a 24mm bar and rear is 22mm, but as we have discussed in private their rear is not what your thinking. I'm going to trial the balance of a 1.0mm diference as in OEM with the 25mm front R31 bar with an custom made 24mm rear on my cars, as I have custom made 24mm poly bushes that fit the standard rear bar mount brackets. (Noltec before Nolathane) I also have poly moustache bar bushes, custom made & rear cross member, before they put them into production.
I also have a solid 20mm rear bar & poly bushes (reddat) & brand new rubber bushes (ex Japan), made to same design as Jenesis (removing the kink at hand brake cable adjuster) that I would like someone to test with a stock 21mm front bar to see what diference, if any? it makes.
Customising suspension from standard is a lot of trial and error unless of coarse you just want to take the word of the mass producers. Nissan has the 1.0mm diference front to rear & Jenesis does the same, yet Selby does a 2.0mm diference and I would guess it has a lot to do with availability and their wanting to stock it of material AND really nothing to do with performance handling. Probably because they are dealing in most cases with dills with street cars that think they can be a boy racer with Selby Sway Bars fitted.
JMO
Cheers, D
hey d were u get the subframe bush from ? is it listed for a zed or something ?
ive got every thing noltec lists 4 r30 bar lower control arm bushs (which ya dont need)
o and i got whiteline 24/ 22m sway bars to suit ozzy r30 bolted up fine
has anyone got a link to these bushes etc? and whats this 280zx stuff fits? cos dont they run rack and pinion?
i probs only need steering linkage bushes (not sure what their called) try and reduce some of the free play. (have adjusted the box). and also rear subframe cos their just old and stuffed now
cheers...
Edited by OUTATIME
http://www.whiteline.com.au/Plus/pdf/WHITE...L_CATALOGUE.pdf
Whiteline Plus is the old Noltec produced suspension bush kits.
Some they kept & some they scrapped, but most of what we use is still available.
Cheers, D
When Whiteline did that kit originally, they were under the idea that a stock R30 rear bar was 18mm diameter.
Cheers, D
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
