  • 3 months later...
Where can I find pictures of the different types of Bride material available? (I'm aware they do a few different kinds). I want to do my door cards to match my seats also.
It comes in the following colours
Black, Blue, Red and Gradation (black to white fade)
100cmx150cm : 6,694yen
76cmx156cm: 6,694yen
Most people say that Bride has discontinue all colour but gradation. this is completely false
Here is the black bride material (i purchase this about 4months ago from bride)
https://www.sau.com.au/forums/topic/307517-bride-material/#findComment-5250064
Thanks man, that's EXACTLY the info I was chasing. So if I am correct Bride material #P01CKO would be just like that except dark blue? or would it be light blue?
I think #P01CKO is just the solid blue colour
I think what you are after is #P02JKO (Fabric Center / ブルーロゴ Blue Logo); as my black fabric has the part code #P02HKO which is センター生地/ Fabric Center / ブラックロゴ Black logo
unsure of what colour blue it is as they only list one colour blue
Edited by Kaido_RR
https://www.sau.com.au/forums/topic/307517-bride-material/#findComment-5252299
Apparently #P02JKO is the light blue colour shown here on this seat
So it seems the same black you got is the way to go for me aswell as my seats are dark blue. Thanks for your help man, much appreciated!
https://www.sau.com.au/forums/topic/307517-bride-material/#findComment-5255238
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
