1988 R31 GTS. Genuine and origonal condition. SVD176. 176 of 200 built. All usual GTS gear. 5 speed, air con, p/steer, LSD, Alarm 16" wheels, biger brakes, bilsteins etc. New radiator, new window tint 3 weeks ago. Custom rego, GTS-176. CD player, Tow bar. Gibson Motorsport front bar, but comes with origonal bar aswell. Vic rego till sept 2010. Vic RWC. Only 113555ks. Selling to buy a 4WD. May consider swap.
$4500.
Contact Paul. 0427852179.
[email protected]
Gippsland Victoria. (near Drouin)
Edited by ausca62
https://www.sau.com.au/forums/topic/307668-skyline-r31-genuine-gts1/
Nice car!
Did these come with factory Bilsteins? Mine has been updated to Bilsteins, and they are just excellent.
Yes. The SVD's came with Bilsteins, thicker swaybar, lower springs and even a different front cross member. The different cross member had a different pick up point for the LCA, to give more neg camber. Cheers Paul
i wont know if i dont ask, swap for lexus es 300?
cheers
Hi mate. The car is my sons and he is selling it to buy a 4X4. Give me all the details, year, ks model etc and I will pass it on to him. Then its his call. Thanks for the responce. paul.
DAMMIT!
if i'd have seen this 24 hours ago i would have been there first thing Sat morning!
PM if the sale falls through.
All the best!
Went to a collector in Frankston. I Had it on ebay n he came to have a look. bought it there n then. Cheers Paul
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
