Hey guys, decided to sell all of the parts I have collected over the last few years. Was going to go into my s14a, but I have other priorities now and need to sell these parts.
No stupid offers please! Please use PM only with your interest, first in with money gets the parts.
Im not trying to make money by selling these parts. All items have been discounted compared to what the sponsors are selling for, even if it is still Brand new. I have specified where i bought the parts from so you can do you research and compare my prices to the sponsors.
Located in Adelaide - Will post at buyers expense, Pick up is welcome.
Cheers
Stephen
ItemPivot Volt Stabilzer kit - Bought from BT Revolution
Condition Brand New, In Box, NOT FAKE! Genuine Pivot
Price $130 + Delivery
ItemDefi Din gauges (Water/oil temp, oil pressure) - Green back lit Numbering - Bought from BT Revolution
Condition Brand New, In Box, All sensors included, All wiring etc...
Price $600 + Delivery
Item Defi Boost Gauge in PSi White Lit numbering
Condition Brand New, In Box - PSi Model Very Rare in Australia. Psi Model was distributed for American Market I was told. No Sponsors sell these
Price $290 + delivery
Item Defi Control Unit - Bought from CJ Motor
Price $170 + Delivery
ItemGreddy Profec B Spec 2 electric Boost controller(Black) - Bought from CJ Motor
Condition Brand New, In Box, Everything Included, Sensor, Wiring etc......
Price $450 + Delivery
Item Greddy Remote switch for Profec B spec 2 boost controller - Bought from CJ Motor
ConditionBrand New, In Packaging
Item R33 GTR Front Brembo Calipers + Endless Pads
Condition Good Condition, Some Clear Coat Missing on One caliper. Approx 57,000kms, Resealed at 45,000kms, Endless Pads %70 left.
Price$1200 + Delivery
Item Blue Silicone Hose (25ft of 4/6mm hose supplied) It is the thermal flex hose as used by Turbosmart - Bought from Midnightmods
Condition Brand New, Still in Plastic
Price $100 + Delivery
https://www.sau.com.au/forums/topic/307686-quality-parts-for-sale-in-sa/
interested in the defi centre gagues.will these slip straight into & replace the factory centre gagues on r33 gtr? do they come with everything or do u need a seperate controll box?
Thanks for your interest mate. These will fit straight into the factory center gauges on a r33gtr. there is a picture actually of these gauges in a r33 skyline dash on the side of the box. In the picture, these din gauges are installed under the climate control on the r33 dash. These gauges come with everything required to fit it in, all wiring and sensors included. All you need is to provide your own water temperature sensor adaptor, and oil temp/ pressure adaptor to plug the sensors into. The water temp sensor adaptor can be the one you fit into your coolant hoses, and the oil temp/pressure can sensor can be fitted into your oil sandwich plate if you have one.
I have these adaptors for sale, but they are for sr20.
have a look in this link to see the adaptors i am talking about.
http://www.nissansilvia.com/forums/index.p...ttach_id=267395
http://www.nissansilvia.com/forums/index.p...ttach_id=267187
Let me know if you want the gauges! cheers mate
Edited by 200SX s14a
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
