Hi,
I have searched and read many threads on here about injector sizing. Many times people mention that 550cc injectors will supply enough fuel for 300rwkw. How is this possible on the standard fuel pressure of 3 bar (43.5psi)?
I have entered the following figures into many different fuel injector size calculators on the net and they all say I will only make 250rwkw on 3 bar of fuel pressure.
I am using the following data:
BSFC: 0.60 (for turbocharged cars)
No of Injectors: 6
Max Duty Cycle: 0.8
Fuel Pressure: 43.5
On the following site it only provides fuel for ~420hp at the engine, which is ~250rwkw.
Am I missing something? Are people upping the fuel pressure or running the duty cycle above 80?
Any help much appreciated!
550cc x6, as a rule, will support 550hp. It's a rough guide of course.
Also remember the fuel reg is rising rate. Base pressure is what, 38psi or so.
Add 20psi of boost, you are now seeing 58psi.
The boost pressure in the manifold restricts flow from the injectors, which is why we have rising rate regs.
If the manifold was at atmospheric pressure, and the fuel rail at 38psi (base pressure), there is a differential pressure of 38psi.
If the manifold pressure is 20psi and the rail pressure was 58psi you still have a differential of 38psi.
Therefore at any given duty cycle, the flow rate will be the same regardless of the amount of boost. (providing the fuel reg is sized correctly and operating within it's limits).
Edited by daisu
Exactly right. Its only ever effectively supplying the base fuel pressure. 1psi of air pressure cancels out 1psi of fuel pressure, hence the factory 1:1 rising rate fuel regulator for forced induction cars.
Where did you get 550cc ~ 550hp?
My 550's are hiting 85% duty and making 340rwhp... however, the current tune is apparently somewhere around 10:1 af's
Standard fuel reg I assume. See that sounds more like it. Sure theres more to be gained from 12:1 afrs but surely not 60rwhp. So people must be running them at over 85% duty cycle to make 300rwkw?
Edited by Harey
1cc for 1hp is just an old rule of thumb, i have no idea where it comes from but ive heard heaps of ppl mention it. but yeah +1 for rising rate reg, high duty cycle and boost. 550s make 260rwkw in mine running nowhere near their duty cycle limits
EDIT: nismo fuel reg and 19psi, cant rmb afr or exact duty cycles as its only recently been retuned
Nismo reg. not sure what the base pressure is set at. But im pretty certain its not 3 bar. Is base fuel pressure measured at 0 manifold pressure?
Edited by Granthem
Do you mean an adjustable fuel pressure reg? Cause the factory fuel pressure reg is rising rate. As said previously boost does not help the amount of fuel getting through the injectors.
They must be high duty cycle if only the standard reg.
1cc for 1hp must be at 100% duty cycle.
Edited by Harey
To be honest I dont think my Nismo reg is being used to crank up the base pressure at all. I believe its simply there from when one of the previous owners was trying to get the most out of stock injectors
you all need to remember/state the 1cc=1hp is only true for a 6 cyl engine . for a 4 cylinder engine it only has 4 injectors so theyd have to be 30% bigger to get same power
Thanks fellers so the nismo reg is the missing piece! Cheers!
No it's not.
Factory reg is perfectly fine is the injector size is correctly given. Which 550's are for 300rwkw.
Here is the numbers @ base fuel pressure (6 cyc motor):
550 cc = 550 bhp
550 bhp / 1.34 = 410 rwkw
410 rwkw – 70kw loss = 340rwkw
The facts.
1. 550's will support 300rwkw.
2. Factory reg is all you need.
If these "sites" say you can only get 250rwkw from 550's... then how is it possible that with 370cc injectors people are making 200-220rwkw???
*think for a second*
Exactly, it wouldn't be possible. To back this up look @ the RB25 dyno results thread every single car with a factory turbo making 190-200rwkw is using factory injectors.
Whatever site you are getting your calc's from - are wrong. OR you are inputting information wrong.
We are the people here that have experience and knowledge of this specific application. Not some "cater for all" website calcuator without any idea.
Injector calcuators are the same as ET/Drag calculators, most of them are absolute rubbish.
can anyone answer where base pressue is measured from... idle? of 0 manifold pressure
My car at idle is 2kg/cm2 fuel pressure... at 0 on the boost gauge... around 2.4kg/cm2
Seems abit off 3 bar?
Edited by Granthem
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
