R32 front drivers seat & rail, including seatbelt
R32 front passenger seat & rail, including seatbelt
R32 rear seat & backrest, including seatbelts
$50 for any of the above ^
in excellent condition, pickup 5162
blue/grey colour, GTst sedan seats
No postage sorry
R32 GTR stock coil packs, in excellent condition
$120 pickup or $135 posted
R32 GTR stock injectors, require new pintle caps,
$100 pickup or $110 posted
R32 GTst stock front brake rotors, near new, with bendix pads, 80% new,
Left & right front, includes stock brake lines
$120 pickup or $170 posted
R32 GTst standard rear wing spolier, silver with centre led,
$50 pickup
No postage sorry
seats SOLD cheers
to sell:
$50 pickup
No postage sorry
I ll take the brakes !!
damnit xD 3rd time in 3 days I get plipped for r32 gtst front brakes >>;
if they arnt gone by the end of the weekend I'll reserve them for you. but Id say they will be pickedup shortly
was for rotors, lines and pads, no calipers.
cheers
sale on rotors fell through
to clarify what is for sale:
Item 1:
$50 in excellent condition, pickup 5162
No postage sorry
Item 2:
Item 3:
Left & right front, includes stock brake lines, no calipers!
Item 4:
$50 pickup
No postage sorry
Item 5:
R33 stock dump pipe & front pipe
$50 pickup
No postage sorry
dump/front pipe sold.
for sale
+ r32 gtst sedan rear seat & seatbelts
+ r32 gtst rear wing spoiler with led brake light
+ r32 gtst front rotors/lines/pads - no calipers!
+ r32 gtr coil packs
1yr old R32 GTR GTS radiator
with black silicon joiners
AAA+++ excellent condition, no leaks, cleaned inside, ready to go
5mins to install, easy as.
excellent results with good radiator fluid + water wetter
$125 pickup, $140 delivered, $150 posted.
no no no
NO calipers.
NONe. The Calipers are mine. Please re-read, I mention no calipers a number of times.
I am selling near new front Brake Rotors, with stock front brake lines, with bendix pads (slightly used)
no calipers, sorry.
Im in morphett vale, 5162, adelaide sa
must sell:
R32 GTR stock coilpacks - exc. cond. - $100
R32 GTR stock radiator - very clean - $100
R32 GTsT stock front rotors & brake lines, with used pads - $125
R32 GTsT sedan stock rear bench seat & seat belts - $50
R32 GTsT sedan rear wing - $25
$100 perfect gtr coilpacks anyone?
$100 perfect gtr radiator? $100 perfect gtst front rotors and lines??
my oh my, so hard to sell top quality for cheap
weird
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
