check out the Shannons stand there - ALOT of old touring and group A cars from Bathurst days on display = f**king WIN!
Awesome sounds good ill leave a bit more time to have a look before hand then
https://www.sau.com.au/forums/topic/307793-top-gear-live/#findComment-5082621
I'm going on the friday night.
I think I see you drive on sam-riley alot come to think of it?
Yeh thats me there isnt many other blue 34's getting around so pretty safe to say it is.
What car are you in cant remember seeing your 32?
I'll be there Sunday night
Edited by FLN75S
https://www.sau.com.au/forums/topic/307793-top-gear-live/#findComment-5082875
Managed to talk to the couple of people i know that went last night, they all enjoyed it and said the show goes for roughly an hour and a half.
Also give yourselves a bit of time to have a look around out the front before you go in as there is plenty to look at plus some motor x guys doing jumps and the stunt riders.
They also mentioned if your driving they parked in the P1 parking complex but they said it was a bit crazy trying to get out so if you can get there earlier enough to be on the bottom level and pay the full parking fee upfront you will get out a lot quicker as the line to pay parking was huge.
Hope this helps. :sick:
https://www.sau.com.au/forums/topic/307793-top-gear-live/#findComment-5083895
I putt around in an 08 red gti peugeot normally. The 32 probably comes out once a fortnight to keep cobwebs from forming. I will give my opinion after my session tonight. Good to know that I should get in early to see some exhibits before hand.
https://www.sau.com.au/forums/topic/307793-top-gear-live/#findComment-5083942
Ah ok i actually think i know the one i shall give you a wave next time i see you hopefully it will be in the 32 looks nice.
No worries let us know what you think.
https://www.sau.com.au/forums/topic/307793-top-gear-live/#findComment-5084010
Went last night, was brilliant. It was definetly better than last year, the hosts were better and the show was better too. They had Skaife/Richards GTR from Bathurst in 92 which I found quite amusing as it was just sitting there being ignored amongst all of the Brockie Commodores and old XC-XD Falcons. If you've never been to acer arena park near the down ramps takes you like 5 minutes to get out as opposed to the 45 minutes it took me last year. May and Clarkson are definetly the better Duo rather than Clarkson and Hammond they have much better chemistry and the jokes were gold, like when Clarkson was staring at this girl with a low cut top and was really distracted then he grabbed the camera pointed it at the girl got her up on the big screen and said "now would you be concerntrating on the show your doing?"
https://www.sau.com.au/forums/topic/307793-top-gear-live/#findComment-5084251
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
