  • Replies 79
YES :D
Just waiting to find map that PVA made a while ago that we can use
Omni -> Northbridge -> Innaloo ->Scarborough -> Burswood
->Fremantle
Think thats how it went. As soon as we get map we can start Nice new thread so everyone can clearly read it and no EXACTLY whats going on, would be nice to have a poll aswell so we know numbers!
Any of you guys have that map handy?
I HAVE A MAP!!!
I got a map, it will be same as our last SDU cruise...
start at OMNI at 8pm... Inaloo-->Burswood-->Scarb--> North Mole-->Freo-->Melvile-->South Perth...
as I said earlier if it's ganna be rain then I'll miss out but I''ll be at the start so I can Give you guys MAP
Cheers
Joe
Cruise NAZI
Originally posted by Pva_Glue
I HAVE A MAP!!!
Cheers
Joe
Cruise NAZI
Are you able to post it up now or will you be handing it out on the night? If you post it up now i will copy it onto new thread, unless if you want to, also as suggested it would be good to do one of those polls it would be srcumdidileeumptios......to see how many people are coming!
Sounds great though!! YAY!!!:D
Well PVa just looked through nearly 900 of your posts on SDU (Man you can dribble ****! :lol: :shake: ) and still no luck! details of that nice cruise must have been deleted from events. OK i will start the new thread and if you manage to find them or can think of it just post it below. If worse comes to worse we can hand it out on the night.
Cool?
OK Then Hands Up if you want Joe (cruise Nazi to hand out a map on the night) AHAHAH man i love dobbing in people!
But Joe you are soooo good at doing the maps none of us could ever possibly design a map as good as what you do.....
Hands up for Joe VOTE JOE NO1!
:D
Originally posted by adam 32
yeh just hand it out on the night i guess
ive got a map from that cruise which it rained and everyone piked on! was a good map but we never got to finish it....
Is this similar to the cruise that we are wanting to go on? ie City west-> Scarborough->Innaloo-> Burswood ->Fremantle... in no particular order? If so Sweeeeeet!!:uh-huh:
Yeah if it is would it be alright to photocopy a few to hand around on the night? You could be our saviour :D
