iruvyouskyrine Posted January 11, 2016 Share Posted January 11, 2016 What do you mean enough* reading? This question would have been answered on here before I'm sure. Read and you shall find. Link to comment https://www.sau.com.au/forums/topic/307965-rb30e-oil-pump-and-oil-restrictors-with-rb25det-head/page/2/#findComment-7665584 Share on other sites More sharing options...
Ruthr33 Posted January 12, 2016 Share Posted January 12, 2016 Haha thanks for the advice. There's so much to read and so many threads. I wouldn't want to have no oil pressure at idle that's for sure. Or 150psi at idle, or catch can filling up. Just wanna drive it like its stolen/to the supermarket. I'm just gonna make my own adjustable setup both on the pump and on the side of the block and fine tune it from there. It's gonna take all the guess work out. Also it would be a prick to hav to take it all out again for the sake of about 40 bux worth of fittings. Link to comment https://www.sau.com.au/forums/topic/307965-rb30e-oil-pump-and-oil-restrictors-with-rb25det-head/page/2/#findComment-7666130 Share on other sites More sharing options...
Ben C34 Posted January 12, 2016 Share Posted January 12, 2016 Haha thanks for the advice. There's so much to read and so many threads. I wouldn't want to have no oil pressure at idle that's for sure. Or 150psi at idle, or catch can filling up. Just wanna drive it like its stolen/to the supermarket. I'm just gonna make my own adjustable setup both on the pump and on the side of the block and fine tune it from there. It's gonna take all the guess work out. Also it would be a prick to hav to take it all out again for the sake of about 40 bux worth of fittings. How you going to have external adjustment on the head feeds? Link to comment https://www.sau.com.au/forums/topic/307965-rb30e-oil-pump-and-oil-restrictors-with-rb25det-head/page/2/#findComment-7666157 Share on other sites More sharing options...
Ruthr33 Posted January 13, 2016 Share Posted January 13, 2016 Probably a needle valve of some sort. Drill 2 holes in the side of the block before it gets to the head, one out and then one back in. It seems pretty basic to me. Haven't put to much thort into it yet. I'm sure someone would have done it befor Link to comment https://www.sau.com.au/forums/topic/307965-rb30e-oil-pump-and-oil-restrictors-with-rb25det-head/page/2/#findComment-7666607 Share on other sites More sharing options...
Ben C34 Posted January 13, 2016 Share Posted January 13, 2016 Yeah, its certainly possible. But is it worthwhile? The info has been around for ages what restricters work with what pumps Link to comment https://www.sau.com.au/forums/topic/307965-rb30e-oil-pump-and-oil-restrictors-with-rb25det-head/page/2/#findComment-7666660 Share on other sites More sharing options...
lcxu105 Posted February 1, 2016 Share Posted February 1, 2016 I'm going with 2x1mm and exturnal oil feed to the vct 3025 neo. Link to comment https://www.sau.com.au/forums/topic/307965-rb30e-oil-pump-and-oil-restrictors-with-rb25det-head/page/2/#findComment-7675802 Share on other sites More sharing options...
Ruthr33 Posted February 3, 2016 Share Posted February 3, 2016 I've chosen 1.5 middle blank the rear and 1.4 to external feed my non Neo head. Hope it's ok. I know it's the wrong thread but I've already got my head recond. But haven't welded the water jacket. Gonna grub screw the oil feed. With my rb30 head gasket there's only 1.5 mm surface area on the side of the water jacket. Has any one had done it this way and had success? It's kinda tricky where I live to get it welded and skimmed. The freight would be the cost of a second hand head. Link to comment https://www.sau.com.au/forums/topic/307965-rb30e-oil-pump-and-oil-restrictors-with-rb25det-head/page/2/#findComment-7677251 Share on other sites More sharing options...
AngryRB Posted February 4, 2016 Share Posted February 4, 2016 i chose 2 X 1.5mm tomei restrictors and the feed for VCT, could be wrong but mine is a street engine and i like the idea of plenty of oil cooling the top end plus the RB30 pump runs the top end of RB30 with 2.4 restrictors so its still a big difference.... oil cools shit down so unless you on a track then why go so restrictive.. 1 Link to comment https://www.sau.com.au/forums/topic/307965-rb30e-oil-pump-and-oil-restrictors-with-rb25det-head/page/2/#findComment-7677995 Share on other sites More sharing options...
lcxu105 Posted February 25, 2016 Share Posted February 25, 2016 Can anyone confirm if the factory rb30 oil restrictors have a one way valve or its a bullshit rumors Link to comment https://www.sau.com.au/forums/topic/307965-rb30e-oil-pump-and-oil-restrictors-with-rb25det-head/page/2/#findComment-7688959 Share on other sites More sharing options...
KiwiRS4T Posted February 25, 2016 Share Posted February 25, 2016 Can anyone confirm if the factory rb30 oil restrictors have a one way valve or its a bullshit rumors I have never heard that rumour but if the restrictor is around 1.5mm it would be a miracle of miniaturisation and what on earth would be the purpose? Link to comment https://www.sau.com.au/forums/topic/307965-rb30e-oil-pump-and-oil-restrictors-with-rb25det-head/page/2/#findComment-7689006 Share on other sites More sharing options...
lcxu105 Posted February 25, 2016 Share Posted February 25, 2016 That is what I thought Link to comment https://www.sau.com.au/forums/topic/307965-rb30e-oil-pump-and-oil-restrictors-with-rb25det-head/page/2/#findComment-7689012 Share on other sites More sharing options...
