Help
Jor33dan
 Share
HI GUYS
my r33 gtst auto is playing up and has almost caused a car too smash into me.
if im accelarating and then take my foot off- the idle drops really low sort of bounces a bit of 500 rpm then just engine turns off??and also happens when i put my foot down nail it then slow down??
has this happened too anyone else?
anyone know how too fix it?
or could anyone fix it for my?? i will pay them!!
cheers
O2 sensor is a sensor in your dump pipe that measures air fuel mixtures tell ur ECU if the cars to rich or too lean and then the ecu will balance the car to run appropriately to many definitions google it but thats what it does in a nutshell .... simply purchase one around 70 - 80 bux new... but i suggest you take it to ur local shop to plug it up to their pc to see for fault codes..
listen we need more info could be anything at this point mate....
- Does the car turn off if u start it and dont touch it....
give us as much info as you can... !!!
ye but when i start it-it doesnt really start unless i rev it.
pretty much i drive take foot off the gas and the revs just drove all the way down it moves a little around 500 rpm then just turns off.
yep i think ill take it too cypher and get the guys too have a look and tell me wats wrong
Be sure to let us know what was the problem once they work it out
good to have these questions answered on the forums if anyone else out there as similar problems =)
i had a similar issue where when it would drop, it would drop straight down the stall, or bounce a bit at 500rpm and die or go back to normal idle, what i did was increase the idle revs and that solved it
my car was doing the exact same took it to the mechanics this thursday gone and they put in a new fuel pump and done something else cant remember haha but its going sweet as now
hey mate wat mechanic did u go too??
and how much did they charge ya
cheers
 Share
    • OK so I just bidded $500 on an R33 GTS4 that no one seems to want. Waiting on a call from the agent to see if I won. 32 GTS4 is for sale. I can't deal with the temptation to mod it.
    • Might be there for work later in the year. Wouldn't mind catching up with you fellas - can't have too many beers, but will consume copious amounts of takoyaki while executing an asian squat on the side of the road while you blokes sort out your hangovers.
    • I know one example is a anecdote not data, but I'm running the same Aeroflow 525 at full voltage through a regular relay, and while I've had other fuel problems including melting the factory fuel hat, the pump itself has been fine for years. Of course, they aren't *that* expensive these days, you could swap in a new one and see if the issue is resolve. I think you had a previous thread about fuel problems, have you been monitoring and logging fuel pressure? Is there anything voltage related (for example does the voltage go up when the pressure goes down)
    • Slap a 460L into the car, send its mum.
    • So last night pulling away from the lights, I lost power for about 1 second. Bit weird, but I kept driving... 5 minutes later the pump completely dies. When I tried to start the car, the pump won't even prime.  I left the car for about an hour, tried to start it and it all appeared fine. Pump primed, car started, got the fuel pressure I should have.... Start driving home, 5 minutes later it dies again. I'm stuck in a shit spot this time going up hill with a car right behind me, so I just let the car continue to turn over while praying to the fuel pump gods. After about 2 minutes of turning the engine over, the fuel pump came back to life and I got home (only about another 5 min away).  So I've been digging around online, it seems like the 525 fuel pumps really don't like to be run at 100% all the time. I've found quite a few examples online of people killing their Walbro 525 pumps within about a year of usage when they are run without PWM.  So, my pump is an Aeroflow 525 (AF49-1057) and I've been running it at 100% without PWM. I'm thinking the Aeroflow 525 didn't like being run at 100% and has burnt itself up.  I really am sick of dealing with fuel pump issues, my current thoughts are -  1. Use a Walbro 450 and run it without PWM. It seems like these pumps hold up pretty well to being run at 100% all the time. I only make about 350kw and can't see me making any more power any time soon so this is probably a fine option.  2. Get a Walbro 525, run it with PWM. I know doing this will annoy me as I feel like with only 350kw, its extra expense that I don't "need" and I'll be thinking the whole time while setting it up that I should have gone with option 1. I know I'll be happy with this option when its setup and running, its only the initial setup frustration and cost as an issue.  3. Get a Walbro BKS1001 brushless pump. This is the fu*k it I'm already going PWM, might as well go full retard. This option just seems better in every way, with the only downside being cost. But I don't know much about this pump so I could be wrong.  Happy to get everyone's thoughts before I go digging around in the fuel tank again.
