Hi all,
I've been thinking about this lately so I wanted to ask you guys/gals on here which fuel have you found to be better... Shell V-Power or BP Ultimate? Especially on tuned engines... ie - 300-350 kw's
Cheers,
https://www.sau.com.au/forums/topic/308118-shell-v-power-vs-bp-ultimate/
Same shit really TBH.
Each fuel is slightly different, but at the end of the day, it's from a pump.
It's not stringently regulated when compared to a dedicated fuel... I think only one manufacturer out of the big 3 actually give a promise their fuel will 100% be 98 all the time.
So whatever is cheapest mate. I use all 3.
BP, Mobile, Shell. Never had any issues with mixed, varying tanks and so on.
i've heard from somewhere shell v-power can go off sitting in the underground tanks which make it unrealiable to use, although if you think about it whats to say the others cant do that.. Could always try and find a United that has 100 octane fuel. I've only come across 1 place since i've had my skyline.
the fuel pick up us about 8 inches off the bottom of the tank . the only true thing is dont buy fuel if you see the tanker has just filled the tanks up yeah there is filters and shit but its not the point . in nz well the south island any way we have bp ultimate and everything else is only 95 . the 98 is superior even notice it in the gf mirage
It was tested on fifth gear (the gay little brother of top gear)
Cars were dyno tested running different fuels, Bp ultimate,V-power and independent servo 98 octane
The BP and Vpower both showed an increase in KW at the rear wheels but the V power made more
It only made a noticable difference in high performance cars, they used a WRX STi and as i remember i think it made about another 10-12kw atw with v-power vs about 8kw with the bp.
Edited by Gough R34 GT-T
Fifth gear rocks.
I use any 98 fuel.
And who guarantees their fuel quality?
I know BP does, not really sure about shell but. Its good if you can find shell 101, havnt seen if for over a year but its not very common.
so hang on, the tests showed that one fuel made more than another
well wouldnt that mean the fuel had less octane count ?
less fuel = higher ratio = more power?
i mean if you put bog stock 98ron in a car and dyno it
change nothing
put 100ron in a car and dyno it
i wouldn't expect a magical power increase
is my lateral thinking not correct?
To correct a mistake, the increases are in Hp not Kw.
Thanks guys for all of the replies. Just wanted to follow up on this one though, why is it bad to fuel up if you see the tanker truck has just filled the tanks up? I thought it would be even better because its newer fuel from the truck?? :)
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
