John from Marvey Tech, its basically all he uses.
www.marveytech.com.au
or call him on 0405 702 292
try Club Sponsor
>>Auto Perfection<<
then Marvey Tech if Ric cant help you out
Auto perfection has Cyclops
Marvey tech has the Mongoose
Thanks guys, this is why I always come back "home"
Andy
https://www.sau.com.au/forums/topic/308146-mongoose-alarms/#findComment-5087037
um club sponsor Carl
to say the least i was pretty pissed the other day to see a couple of members talking shit about club sponsors :)
we have sponsors for a reason Ric has put his money where his mouth is on many occasions the first being window tint group buy the last being sponsor ship and prizes for the simulation event... need i go on
https://www.sau.com.au/forums/topic/308146-mongoose-alarms/#findComment-5087462
Yeah, im aware steve :D the :( in my post was intended to infer that i was joking. I reckon you would make a good salesman though, keep pushing through those objections. like they say, its not really "no" till you have heard it three times
https://www.sau.com.au/forums/topic/308146-mongoose-alarms/#findComment-5087546
hey vu
good idea...
So andz, whats the deal with quoting my opinion on mongooses?
Theyre a decent alarm when they work, but the failure rate from the OEM is pretty high
Care to clarify why you think its sig worthy ?
-D
https://www.sau.com.au/forums/topic/308146-mongoose-alarms/#findComment-5087595
-D
nvm du ma
-D
I used to work at electric bug they deal with mongoose alarms. If u do go there ask for Paul he was the only one with good knowledge
cheers :)
these guys should advertise hey...google couldn't help me find any dealer in Adel
word of mouth ftw
https://www.sau.com.au/forums/topic/308146-mongoose-alarms/#findComment-5087691
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
