Hi all,
Im getting a Tomei Trax 2 way fitted this week. But i have been told if you change the cam angle you can make it a 1.5 way. Anybody done this?
Reading some info on these diffs it seems they were designed for drifters. Has anyone had one of these diffs installed? Are they very harsh to live with?
https://www.sau.com.au/forums/topic/308309-tomei-trax-lsd/
honestly, you just get used to it... and pretty quickly....
i have a weldy in my ke70 and i dont even notice it :)
i have a 1.5 way in the r33 and that's the way to go for a car that isn't dedicated drift imho
https://www.sau.com.au/forums/topic/308309-tomei-trax-lsd/#findComment-5089787
Hi all,
I'm not sure if you can change the cam angle in the tomei (i was under the impression that it is a fixed), however the lower the angle cam will result in mild locking characteristics, also it will reduce the chattering characteristic of L.S.D.s, reducing unexpected motion changes and increasing stability, allowing it to be used enjoyably on the street.
Nismo lsd GT lsd are all 55 degree cam angle apart from the PRO TT which uses a 45 Cam angle
Advantages of the 45° Cam Angle
A 55° drive-side cam angle in vehicles with reinforced bodies can result in the inner tire moving in a minus direction during cornering, creating drag which can result in reduced times. By reducing the lock ratio by decreasing the drive-side cam angle to 45°, tire drag during cornering is reduced and circuit times are improved. A lowered cam angle also decreases the power to each plates, providing more stable initial torque.
NISMO's Suggested Users
1. Circuit users
* Tuned cars with reinforced rear areas
* Tuning shops time trial demo cars
2. Street users
* Those who want an L.S.D. that is moderately effective on both winding roads and on the circuit
* Those who want to use an L.S.D. in street driving but dislike the chattering
So in short if you can reduce the cam angle it will still be a 2way but be more street friendly
https://www.sau.com.au/forums/topic/308309-tomei-trax-lsd/#findComment-5090205
I'd be much more worried about putting 390rwkw down than what happens when you back off! lol
seriously though 2 ways are fine on the street... you have to be a complete muppet to spin it on lift off... if you jump on the anchors and have lots of steering lock on it will step out but very controllable
https://www.sau.com.au/forums/topic/308309-tomei-trax-lsd/#findComment-5090491
Diff is in. Feels pretty good. Terry was able to make it a 1.5 way (near enough)
Bed it in for about 15mins as instructed, but ill give it another go later just for piece of mind that it is done properly.
Terry and the boys at Award did a perfect job and their customer service is second to none. Ended up costing cheaper than quoted which was a nice surprise.
https://www.sau.com.au/forums/topic/308309-tomei-trax-lsd/#findComment-5096193
Terry, Trish and the boys at Award did a perfect job and their customer service is second to none. Ended up costing cheaper than quoted which was a nice surprise.
Fixed...don't forget Trish mate...she a classic.
https://www.sau.com.au/forums/topic/308309-tomei-trax-lsd/#findComment-5100482
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
