So ive got my wideband controller working on the bench, time to hook it up to the car and get some data logging done.
The wideband controller has various inputs for speed, rpm etc... all from the ecu.
What I would like to know is, what is the best way to tap into the ecu to get the signal? Im fearing the only way I have is to cut and re solder the wire harness as it comes out of the ECU.
https://www.sau.com.au/forums/topic/308608-best-way-to-tap-into-ecu-wires/
STOP!!!! Dont cut the wires, just strip some of the coating off them and splice the wires you wish to tap in around the bare ecu wires and solder them together and
tape it up with some good quality electrical tape.
Picture care of evilution.co.uk
Picture care of legacygarage.com
Hope that helps. :thumbsup:
99 GTT, perfect, actually dont know why I didnt think of that its so obvious...
errno, i've seen those before, but im a bit skeptical, what if they cut in too deep, id worry about the wire breaking over time.
Thanks guys, off to do some soldering tomorrow and hopefully logging some AFRs
Edited by ascenion24
These join every phone line cable in NSW, look inside those cylindrical junction boxes and you will see hundreds of them, Ive used them on and of for the last 20 yrs and had no problems.
if they cut only the insulation then there not making contact with the copper, so they must come into contact and therefor cut the copper wire to some degree.
Im guessing you'd have to know the thickness of your insulation to get the right size of those joiny thingos... seems to much of a pain in the ass considering the consequences could be no connection or cut wire.
http://www.takakaira.co.jp/Main.aspx
Field one touch connector FTW!!!!!!!!
Not a cheap option but undoubtedly the BEST way
combined with the strip an solder method I think
If only temporary though Solder a bit of solid wire to ya leads
an push into the back of the plug
Edited by noone
a while ago i thought i'd give those little clip things a go, to install a SAFC on my old 32. driving up the motorway one day and the unit just died, hence my car died. not fun at 100kph. it was that little clip splicer thing that wasn't giving a good connection, and yes i did use the correct sized one for the cable i was splicing. i wouldn't recommend them to anyone.
what i like to do is cut the wire. strip the ends. slide a piece of heatshrink down the wire. solder it back up. slide the heatshrink over the join and shrink it down. you cant go wrong if you solder a wire properly.
Put your credit card against your leg, is it touching your leg, has it cut your leg.
Do you use M8 bolts to go onto a M6 nut, of course not, you use the correct size.
Ive connected up my shift light recently in 20 seconds, that included wrapping the connection in insulation tape, and, there is no drop in volts from the ECU to the light.
Ive used these for 20 odd years and if you do the job correctly you wont have any problems.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
