Damo's R32 Gts-r, On Going Project Fun Car. History And Use Full Info
thanks for the kind words guys.
my new rose joints arrived so ive cleaned up the old adjustable JJ arms. and painted the blue ones so they look the same
all ready to go again
After talking to a Man in the know it was decided that changing the roll center of the rear without doing the correct calculations may do more harm than good so my half modified sub frame has been put to the side and i spent a bit of time today doing the small mods to my old sub frame. i also wanted to get the car on its wheels and going in the next few weeks so spastically modified sub frame is on hold again.
In an effort to make the car a bit more subtle for my re-entry to motor sport (i havent drifted anything for nearly 12 months) ive painted the D Max rear wing gloss black to match the roof spoiler.
And the bonnet that looked good on the track actually was a spray can job done over 2 winter nights on the lead up to a drift round. the paint was so wet on the morning that my GF put a hand print in it. so the Gun Mr Chad sanded and prepped the bonnet read for a new coat.
coat of saturn black. the pain was not mixed quite right so were not sure if we will go matt or gloss from here.
and the rear going back together
and a quick snap shot of the track wheels
R34 GTR wheels on the back and 17" CST hyper Zeros on the front.
calipers have been painted silver after seeing a sexy GTR with silver brembos recently. much nicer than red or blue that you see on any old ricer.
i always aim to do more but if im not running the engine in by this weekend ill be sad.
I like the silver subframe and calipers :)
Was it much of a drama getting the new rose joints to suit the arms or are they fairly common?
well if they are imperial (meaning american and speed way useage) they are easy to get but these were metric but turned out to be a common size. i had 3 different brands to chose from and 4 different quality ones to chose from. i got teflon coated middle of the road options as i can aford to replace them many times before buying the expencive shit
the idea behind the silver subfame is not to make it look like a billet alloy one (joke) but light colours show up cracks and oil leaks easy. they also reflect light making working under the car easier.
I painted my engine block light blue for the same reason...makes finding things so much easier.
Ill have to check out what thread my joints are then...
thanks for the info :)
car not has track wheel alignment. race tyres are sorted and should hit the rollers over the next 2 weeks. depends how much time the tuner i use sits in his office on the interwebs.
im pretty happy with the look at the moment so ive taken some pics.
if you look closely in the last pic you can see a riverted carbon panel. its a temporary measure to fix some "body imperfections" untill the wide body goes on.
We took the car out for a couple of hours run in on the weekend. The car's on a very consertive tune ATM, so it'll be interesting to see what it's like when it gets a proper tune.
Great thread Damo the car's looking fantastic. Keep up the good work. Ask your mate if he wants to buy the JZX90 because I want to get an M35 Stagea.
got the car back from the tuner. found some problems that need to be addressed then back on the rollers to see what it will do power wise.
all i can say is wow it has a massive initial punch and comes on strong. the throttles are very noticeable.
bigger turbo time already.
ill be taking it to a club day this weekend to give the car some track time to trial all the bits that have been done over the past few months.
I just realized somthing...was that my old turbo that went bang....I sold you one back in feb 08
Im pretty sure not. it was a Neo turbo that i got of a local bloke who got it off some one off nissan silvia who my have been you now i think of it. who ever he brought it off i got in contact with prior to buying it to make sure it was legit.
I have brought a few other turbos to use on mates cars ect thoe. one of them being a r33 turbo with a blown oil seal for parts.
Ok so a few weeks worth of updates and some more to come in the next few weeks.
so we start with my self inflicted Dyno dramas. first off the car developed a charging issue which i doubted to be the alternator as i had done it up while the engine was out. it turned out to be a plug i had used between the alternator and isolation switch. it had melted due to high current.
i fixed this friday night after doing a few quick jobs on the Porsche i was crewing for in targa. All sweet i though.
than on the saturday morning it developed a cutting out issue. i remembered that we had found that the air flow meter plug lock tab had been broken and the plug kept coming off but had forgotten to repair it before going to the dyno. then the car shut down for a final time and wouldnt start.
When i picked the car up i found that it had a blown fuel pump fuse as during the engine build and subsequent modding the fuse had been swapped over. (or at least thats what im saying)
so i got the car home and started on a list of things to finish off before the weekend track day.
this included fixing the air flow meter plug. the wiring to the alternator and wiring in the air temp sensor in the GTR plenum. then i wired in bens Track Mate data logger ready for the weekend.
i also put in my new second hand oil temp gauge only to find that it didnt work. i had tried it under boiling water before hand thoe to make sure i wasnt waisting my time and it worked fine then.
The knock sensors in the new motor dont seem to work very well so been started to try to remove them ready to replace them with my old knock sensors. he then found that it is impossible to remove them with the plenum hanging off the head. so unfortunately i dont have decent working knock sensors any more.
after sorting out the car we gave the new test pilot the run down on the controls.
so the club day starts off fine with been tweaking the tune ever so slightly. first thoughts of the new engine are grate. then my suspension mans car broke so i offered up a seat. (im very happy to lend a seat to mates as this is a fun car not a greedy car) first lap out and into the second last corner he compression locked the back end spinning him off the track and through a swamp. (well it may as well have been) he continued a few laps then came in and washed the mud out of everything.
during the day i had the car cut out as i was lining up on the start line. i found this to be caused by the air flow meter its self as the plug is now 100% right. So tonight i pulled the AFM apart and found 2 dry solder joints. i fixed them up and put it back together.
it should be on the rollers bey early next week at the latest and i should be able to play with the cam timing a bit as well.
all in all the fun cars back.
Well more self caused dramas on the tuning front.
all sorted for now to get a few events on this new engine.
Car made 200rwkw which is lower than the original 219 bef. but the 2 can in no way be compared which is disappointing.
new power = GTR intake and fresh engine with head work. but also new dyno and smaller turbo (r33 gtst)
old power = original intake. 17 year old engine and r34 neo turbo.
so in the last week ive take the car from this. Track setup and half stripped to remove the mud form the car.
to a presentable Drift Car
and with some help from the trusty ben the cars all most ready to slide or win as he says.
so while every one is at Super Nap ill be at the second round of the state drift series.
well my weekends done and dusted.
Saturday started out ok but half way through qualifying the car developed a miss and was was running on 5.
i qualified 10th out of 18 drivers for the day.
we wipped the plugs out during the lunch brake and one of them was not like the others. so we put a new set in and hoped for the best. unfortunately the miss was still there and i had to retire from my battles. after watching for a bit i decided to start swapping bits off my mates car but still had no luck.
all in all the handling of the car with the cage and seem welding in the front has made it very predictable and the power comes on hard but its lacking about 40kw in the top end.
some modified knuckles are next on the list "to do" after sorting the current issues.
PS: i hate bringing a car home that doesnt work properly.
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
