OK, so to give you a short version of the story:
I was cruising along in my R32 GTS-t do around 100km/h when all of a sudden it tried to stall/die on me about 5 times.. I wasn't on boost or anything, just cruising..
.. So I took it to the mechanic, who changed the fuel filter and ordered a fuel pump for it as he said the pressure out the the factory one was very low, indicating it was probably stuffed..
.. THREE WEEKS later he finally got some cheap looking no/name brand and fitted it.. When I drove the car after that, it tried to die/stall EVERY time it hit boost.. So I took it straight back..
.. He seemed to think maybe the pump was faulty or the wrong one.. At this stage I had really had enough, so I went on the net and had a 500hp Walbro pump delivered the next day.. Took it into him, and got him to fit it..
.. The car now seems to run sweet, wether cruising or boosing.. BUT.. if it comes to rest or idle, it now stalls/dies.. OMFG!!!! After fitting the pump that he supplied, I reset the ECU, other than that it had had the fuel filter changed, and I got an oil change while I was there.. Other than that, the car is fairly factory other than a turbo back 3" exhaust and a KN Panel filter. Also the car is an auto and is still running the factory RB20DET...
If anyone has any ideas what could possible be causing this, PLEASE let me know as I really miss my car and I'm not really sure this mechaninc knows what hes doing anymore
Cheers,
Damo
Edited by Damo Monster
https://www.sau.com.au/forums/topic/309358-omg-month-long-fuel-pump/
Damo, try cleaning your AFM or changing it with another to try.
cheers for gettings back to me.. i dont think i have any hope of finding another afm anytime soon, so how do i clean the one i have? could i pull it apart and use contact cleaner or something? cheers
Take it out and spray contact cleaner on it , try not to touch the wire with anything , just give it a few hits, read the instructions on the can they're pretty helpfull.
:rofl:
In regards to the stalling , is the type where u pop it into netrual and the revs just drop and car dies when you stop , if its that then that sounds like the blow off valve issue or afm dirty or the throttle body needs to be cleaned
no it seems to be the type where i slow down at an intersection, car still in drive with foot on brake to decelerate and once the cars comes to a rest, the revs drop right off and it dies.. if that helps isolate the problem? :)
Take it to a mechanic who knows what he is doing. Start with a diagnostic check
lol.. yeah its funny how much faith we put in people sometimes.. i dont know anything about car repairs, but im starting to think i might as well have had a crack at it.. anyway, he has some bloody expensive scanner computer thing that he attached to the car in the beginning, but everything lit up as ok.. he also put a fuel pressure guage on the fuel lines near the engine, and thats when he said the factory pump was putting out very low pressure, and was probably the cause of all the probs.. the thing i cant figure is the change in the three pumps.. the factory one would cause the car to try and die whilst cruising at 100ks.. the second one he supplied would cause the car to try and die everytime the turbo came on.. and finally this walbro one seems to make it run sweet once its going, but cant seem to idle.. and come to think of it, im sure that car had a backfire when i was booting it a bit to test the car out with this walbro pump fitted.. it only happen once, so im not sure weather it was a backfire, or perhaps maybe i just hit a rock or something..
.. is there any chance the walbro pump would be poking far to much gas at the engine causing it to flood when trying to idle?
The airflow meter needs to be swapped with a know good one. Its probably the issue. While you are there check for leaks and tighten all hose clamps, make sure all hoses go somewhere.
The plug pins where they go onto the circuit board of the AFM may have broken, these can be repaired with a re-solder.
These pumps need 13.5V to operate properly.
Did he wire in a new voltage feed and relay for the new pump?
The std wiring has a resistor circuit that is switched in at idle...starving the pump of voltage and starving your engine of fuel.
lol at the AFM people...he says it runs fine whether cruising or boosting so why say its the afm when it appears to be metering the air nicely.
Edited by DiRTgarage
no, he just did a straight swap on the pumps.. as in factory one out, new one(s) in to factory wiring.. didnt know about the resistor circuit stuff.. is it easy enough to bypass on the r32s?
will try and examine the existing afm tomorrow.. as i said before, finding a known good one will be pretty much impossible for me to do, short of blindly buying a new one from nissan (which is probably worth more than the car :) )
cut the earth going to the pump from the FPCM and attach it to a suitable earth somewhere on the chassis/body.
oh god, im gonna sound dumb here, but i have to get this right so i can relay what to do / do it myself tomorrow.. what is the FPCM? would i be right in assuming that you are refering to the wiring loom that goes to the top of the plate where the fuel pump live under (i seem to recall it ends up being about five or six spaced out terminals)? and would i be right in assuming the the resistor is attached/switched on the ground wire, hence cuting the ground wire to the pump and simply earthing it to the body will result in it getting 13.5v full time?
thanks so much for the help!!
FPCM = Fuel Pump Control Modulator.
The earth can be grounded behind the drivers side boot trim as it runs up here to the rear drivers side under the trim where the FPCM lives.
Doing this wont give the pump 13.5V but it will run it so it will behave at idle. The factory wiring drops up to 2V with the increased load of running the larger fuel pump but in some cases ive seen it as low as 10.5V with the earth wire mod. done.
Doing this wont give the pump 13.5V but it will run it so it will behave at idle. The factory wiring drops up to 2V with the increased load of running the larger fuel pump but in some cases ive seen it as low as 10.5V.
fantastic, that seems to make a lot of sense.. it didnt occur to me that the new pump could draw more power (at least at the time lol).. i brought the walbro 341 cause i was told it was a straight replacement for the factory one.. thinking the mechainc should be able to manage with it i hoped i was doing the right thing..
i'll get a multimeter onto that pump tomorrow and see whats happening with the voltage! i take it that you had to do this mod before?
OK. i havent read all posts, but sounds like the mechanic had grounds to blame the pump. now if he checked fuel pressure inline at the rail, he could have possibly overlooked the fuel reg.
to test, find a way to clamp the hose after the reg. to do this i usually use vise grips. DO NOT drive the car like this for long, it will kill the pump and/or spring a leak.
I know this is a very crude method people, but it will overcome the possibility of the reg, i recommend you try.
yikes, just re-reading your post.. you have seen the pump drop to 10.5v WITH the earth mod done?! i hate to think what they are dropping to with just the factory wiring on their own.. they should warn people about this in BIG print on the box lol!
physically inspect the fuel pump
is it installed and mounted correctly onto the factory bracket on the roof of the fuel tank?
or it sloshing around in the fuel tank (common botched installation)
should take 5 minutes to check with a torch (no naked flames as tank is exposed)
you can open the tank from the top on the parcel shelf, square panel, 4 bolts
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
