hey guys im looking at running braided oil drains because of the hot stainless manifold just wouldering what size weld on dash fittings would fit best -8 or -10? im thinking of welding a fitting on the end of the bit that comes of the block and another one on the drain bit of the turbo? just wondering what size fitting?
cheers
Use this gear over the drains, if you CBF'd using an fittings
http://www.mpsracing.com/products/Earls/Flame_Guard.asp
id rather use fittings in think? the drain is like 3mm of the manifold. would -10 be ok or should i go to a -12?
That flame guard stuff is useless if it gets too close to the manifold, mine has dried out and just crumbles when you touch it.
-10 on the drain will be fine
ATP, GCG etc all sell an drain adaptors for around $30-40 and I'm using a speedflow adaptor out of the block (currently rubber on a hose tail but will be repacing shortly).
Steel pipe will be ALOT more durable than any braided lines when mounted close to a heat scource, reguardless of what you wrap them in. The red firesleve (aeroquip) is designed to be a flash flame protection cover not an absolute thermal barrier for 1200 deg C...
My suggestion is to use the standard or standard style drain tube. Get the drain tube to line up 5 or 6 cm from the drain fitting on the block and use a short peice of high temp rated hose, with good quality stainless steel hose clamps to join them. As long as you flare the ends of both tubes, the hose will never come off.
If your super woried about leaks, just double clamp each end.
My 2 cents
Justin
^ I think they can input whatever they want.
I can see this being another classic SAU discussion.
make a solid oil drain pipe out of stainless dont even need to worry about mandrels just keep it flowing down wards and lobster back style it.. than use 3/4" aeroquip hose from the drain pipe to the fittin on the block. usually takes me about 20-30 minutes to knock one together, its never goin to melt because its to close to the manifold, its never goin to run the risk of collapsing
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
