  • Replies 76
For a GT-RS on a RB25 it seems to be coming on fairly late at 3600rpm.
The peak looks about right so there is still room for more power earlier when that is sorted. I'd expect it to be all in about 500rpm or so earlier.
I think he is concerned that excessive blowby will develop if I go any further HP wise.
Apparently the standard exhaust manifold starts to become a restriction at this level too, ie excessive exhaust pressure/heat buildup. Correct me if I'm wrong.
dont think so dude... i had my old car making 290rwkw on the standard manifolds and it was all good... no catch can either :D
he must want you to have it as a precaution rather than anything else...
Edited by usmair
The manifold is not an issue at that power level.
I would have a look at the wastegate as a reason for the lazy-ish boost response.
So thats just a matter of fitting a tighter spring, right? Would the stock BOV have anything to do with this ie leaking?
dont think so dude... i had my old car making 290rwkw on the standard manifolds and it was all good... no catch can either :)
How long were you running that power level? How do you know you didnt have blowby if you didnt have a catch can?
I dont think you will get much more than 250rwkw out of a GTRS on a stock RB25. But it should have really good response.
If the stock bov was the issue you would have issues with high amounts of air not with response.
Mine GT-RS runs 256rwkw @ 14psi.
However, it has headwork, HKS cams, Plazaman plenum aswell.
Nice results! Bet you are happy. Gets boring quick tho :P
Edited by Granthem
Standard everything else, RB25, Powerfc, injectors, FMIC, exhaust, and GT3076 with 56trim, 0.6 comp cover, a 0.63 IW rear housing, 18psi of boost. Full boost at about 3100rpm.
Boost was on steady here to stop traction loss. Came on hard though, and at around 3000rpm as I said.
Set up the 3076 properly, and it will not be laggy.
Er.. while thats annoying to see it spooling earlier than my smaller turbo, its not entirely relevant now that I have a GT-RS :P
I am pretty happy with the way it drives though, much smoother coming onto boost.
Unfortunately after 6 months of being f**ked around by yellow sticker, getting hail damage, and having it stuck at the workshop for 3 weeks getting tuned guess what.. its been raining all day yesterday and today, which means I can't really test the acceleration properly.
since we're posting set ups...
heres mine... stock neo motor, un opened except for poncams type b's, has AM performance stainless steel steam pipe manifold with custom collector, 3076, tial 44 gate, fmic, 3.5 inch exhaust, nistune, 600cc injectors and runs 50/50 ethanol/bp98
running 16 psi too... its crazy to drive and is very VERY responsive. torque chart was on the wrong read out when they printed it but it makes around 550 nm torque at the wheels.
Check the wastegate preload SoFreshSoClean. If the actuator has some play in it, crack the 10mm nut and go a turn or two!
This wont need retuning because the AFM compensates for the extra air and adds fuel right?
Gonna have a look-see tomorrow. If its stopped raining. Which it hasnt. :)
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
