1. use common sense
2. search
the information is readily available on the forum, you can use any RB series powerfc. obviously you cant easily get one from another car and get it to work.
because all RB's are fairly similar electronically and the powerfc has the ability to be tuned, you can get a powerfc from any RB powered skyline to run any other. BUT, only the R33 and R34 powerfc will do the job PROPERLY. the R34 has variable cam timing, only the R33 and R34 powerfc has the components inside to run that. using a RB26 powerfc is cheaper but you need to redo your wirring harness and you lose control of the VCT.
the VCT (variable cam timing) is makes the car alot more powerful down low, without VCT the car will feel alot laggier unless you get a really good tuner to tune it out with adjustable cam gears.
the forum is FULL of information, more than you will find by asking questions and usually you can ask your question in a topic that is already going.
If you have any questions about how to search, please ask, if not I have armed you already with more than I should have.
Goodluck
1. use common sense 2. search the information is readily available on the forum, you can use any RB series powerfc. obviously you cant easily get one from another car and get it to work. because all RB's are fairly similar electronically and the powerfc has the ability to be tuned, you can get a powerfc from any RB powered skyline to run any other. BUT, only the R33 and R34 powerfc will do the job PROPERLY. the R34 has variable cam timing, only the R33 and R34 powerfc has the components inside to run that. using a RB26 powerfc is cheaper but you need to redo your wirring harness and you lose control of the VCT. the VCT (variable cam timing) is makes the car alot more powerful down low, without VCT the car will feel alot laggier unless you get a really good tuner to tune it out with adjustable cam gears. the forum is FULL of information, more than you will find by asking questions and usually you can ask your question in a topic that is already going. If you have any questions about how to search, please ask, if not I have armed you already with more than I should have. Goodluck
THANKS FOR INFORMATION. NORMALY I WOULD DO AN EXTENSIVE SEARCH BUT WHEN I TRYED ALL I GOT WAS A POST ABOUT STEP 1 AND STEP 2 ON UPGRADING. IM ON MY PHONE AT WORK SO THE PAGE LOAD TIME IS LIKE 10MIN.S SO I FIGURED ASKING THE QUESTION WOULD BE QUICKER THAN TRYING TO SEARCH WITTH THE SLOW PHONE SPEED
When you get home, follow these two links http://www.skylinesaustralia.com/forums/Fa...req-t64201.html http://paulr33.skylinesaustralia.com/docs/...erfc-faq.htm#55 just about everything you could want to know about powerFC
THANKS MATE WILL  DO (ONLY FOUR HOURS OF THIS SHIFT LEFT GOTTA LOVE NIGHT SHIFT).
lol better hope ur getting paid well, im going 2 bed :blush:
YEAH PAY.S GOOD BUT THE WIFES PUT HER FOOT DOWN AND SAID SHE LET ME GET THE CAR I WANT BUT NO UPGRADES TO THE CAR TILL SHE GETS THE UPGRADES TO THE HOUSE :D ONE DAY !!!!!!
lol then buy the car with the upgrades already and tell her ur saving up for the house... "its not like i dont want to work on the house hun, afterall once im done i can work on the car too :D"
mediation, atleast they think so :blush:
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
