Well he could chuck a W16 in if he wanted to, but hes asking about an SR.
Conversions are an expensive exercise and time consuming. I strongly believe that 1j is cheaper/stronger/makes more power then an SR, so before the guy jumps into it, i thought i would bring those points up so he can decide for himself.
But i guess being a cocky smartass and not putting forward anything useful is where its at. My bad.
  • Replies 40
to prove a point :)
chuck one of these in it yo
http://people.bath.ac.uk/ccsshb/12cyl/
-D
hows about those figures
108,920 hp at 102 rpm
5,608,312 lb/ft at 102rpm
I reckon they should do drag racing with oil tankers. Quickest quarter nautical mile from 0 knots haha. Would be more entertaining than lobster racing.
-D
where is a good place to get a 1j or 2j?
the pintara cross member works because the CA20 that comes in them uses the same mounts a CA/SR motor... one of my mate put a CA18 in and that was different... the standard CA20 box bolts up to a CA18 also... maybe that would be the path to go
otherwise the SR will be great but you need a SR box to and possibly a custom tailshaft
hope i can help
CA20 boxes are also f**king shit and will be blown up in no time. I know I ran one behind my CA18det bluey which was dead standard apart from exhaust and still shat a box
come on Josh... i just said it would bolt up.... i never mentioned that it would be strong!
I ran one behind a CA18 as well with similar luck... but who said this bloke would drive as hard as we would?
Just get the SR going mate...
And if you are as good with electronics as you say you are.... we should talk as I need some stuff sorted :)
why not lol nah mite go rb26 not sure, or maybe 25/30
There was a 2jz r33 for sale from 1 of the importers, forgot which 1....it looked sweet as.
I am aware of both of them thanks damo, anywhere else?
private sales (off forums) or even yahoo auctions japan. couple guys of the forums import stuff, including some businesses.
That could have something to do with ur grandma driving as well lol :D
  • 2 years later...
Just incase anyone was wondering out of interest I got this car going I picked up an sr20de with box loom and ecu. Bolted it onto a ca20 cross member and used standard gearbox mounts and standard driveshaft from pintara. Used sr20 power steering pump and connected the standard 31 lines to it. Car doesn't go too bad for what it is and is much better in fuel.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
