hey everyone i need some help to fix my problem
CAR: Nissan Skyline R33 GTS-4 AWD With modifications.
PROBLEM:
The problem is my steering, in the morning when i first start the car and drive it the steering get stuck to the left, not stuck in the way where i cant move it, the steering wheel is just on an angel to the left not dead straight and i have to go left to right on to get it dead straight.
It also happens when I'm going 80kph + around a bend or so it pulls left and then back and then left again and it is dangerous and it unpleasant to drive.
also when going over numerous bumps on the road (only small ones tho) the car will go slightly left to right really fast and i can feel the back ones moving also.
MODIFICATIONS:
I HAVE 17" Wheels (One is different)
Have New Tiers (Fronts are the same Rears are differnt to each other)
Aftermarket KYB Excel- G Gas Struts
King Springs in front
Cut Springs in rear
MY SOLUTION ON WHAT I THINK IT IS:
After i changed my tiers i went to Bob-Jane T-mart for a wheel alignment and wheel balance and maybe they didn't do a proper job not sure.
or
maybe because the springs in the rear are cut and its lower in the rear and its throwing everything off.
MY POWER STEERING PUMP HAS A LOT OF AIR BUBBLES IN IT IF THAT HAS ANYTHING TO DO WITH IT
ALSO i do not remember if the car was doing it before because it was off the road then i first bought it because i was changing a few parts like clutch ect before i put it back on the road
I'm not really sure of the problem so please help me out as much as you can.
thank you
Edited by niiko101
https://www.sau.com.au/forums/topic/310412-r33-gts-4-steering-help-asap/
I have had this problem before and this is how i corrected it. Im not saying it will solve your problem but it is worth a shot as it works for me every time.
Hop in your car and drive it up your drive way steering it straight so the car goes straight and then stop and park the car. Dont reverse or turn the steering wheel. Ignore the steering wheel being not center, we will get to that later. Once you have done this, turn the car off and pop the bonnet. Pull the battery lead off and leave it off for about 5 min to discharge the car. Another cheats way of not waiting to discharge the car is disconnect battery and then press your foot on the brake. This will also discharge the car straight away without waiting.
In the meantime of discharging the cars power with the battery lead off, turn your steering wheel to right so it is straight. Ignore that the wheels may have slightly turned. Once you have done this and the steering wheel is straight, put the battery lead back on and start the car. DO NOT move the steering wheel. Let the hicas computer relearn its positioning of the steering wheel as it will notice the steering wheel sits as being center. After about 5 min turn the car off. Give it a min and then start it taking it for a drive to see if it corrected itself.
What happens is if you do a battery change or you disconnect the battery for a while and you have your steering wheel not straight when you put the battery leads on, it will think that this is the new center point of the steering wheel. Ive done it a few times were ive disconnected the battery, turned the steering wheel, reconnected the battery and then found the steering wheel to not be straight with the wheels. Doing this process above always fixes my problem.
I hope it fixes your issue. :D
thanks for the tip man and ill give it a go right now and let you know if it worked altho i dont have a hicas i have a altessa 4wd system but its worth a shot doesnt hurt to try
Edited by niiko101
the method you have discribed won't fix any problems with the front wheels not lining up with the steering wheel. it may fix any issues with the rear wheels, but not the front as it is a mechanical link between the front wheels and the steering wheel. the steering column actually turns the steering rack and the front wheels cannot move without the steering wheel moving, and vice versa.
also if your power steering lines have air in them or the pump is shot you will get vibrations through the steering wheel and it will feel jerky when you turn the wheel. i have driven a 180sx with a dying power steering pump and it had similar symptoms to what you are describing.
The last time I got a Bob Jane place to do a wheel alignment, the steering wheel was off centre. Go and get a new alignment, centring the wheels to the steering wheel (ie steering wheel "straight ahead").
Get rid of the odd wheel and tyre on the rear. The odd (mis-matched) rear tyres make the car unroadworthy (unless you are running the space-saver spare). And check the fluid level in the P/S pump.
is the power steering pump ment to have air bubbles in it tho ?
Edited by niiko101
not that i am aware of. but what do you mean by bubbles? do you mean tiny little bubbles in the oil, or bigger bubbles? sometimes fresh oil will have tiny bubbles in it, but generally not. it is a hydraulic system and it works by pressurising the oil, as oil doesn't compress very well, but air does, so any air in the system will make it not function properly.
also is there any noise coming from the pump when you turn the wheel or even just at idle?
could be that your power steering pump is stuffed, or possibly even the steering rack is stuffed
If you have odd wheels / tyres on the car, sort them out so that the wheel / tyre combo on each axle, at least, is the same. Then you might be in a position to diagnose what the problem really is.
  • 1 month later...
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
