Ok, I have purchased a second hand pair of r33 gtr front driveshafts and would like to get them reconditioned before i fit them.
I have used a driveshaft mob in hawthorn many times before and do not want to use them as they are very hit and miss.. they get it right sometimes but other times they dont and i really only want to do the job once.
can anyone recommend a place in melbourne... i have looked on yellow pages and there are plenty:
Driveshaft Joints in Melbourne
cheers.
https://www.sau.com.au/forums/topic/310418-driveshaft-mobs-in-melb/
cheers.
+ 1 for
Hardy Spicer
U1/73 Remington Drive
Dandenong South Victoria, 3175
Telephone: (03) 9799 3250
Made up a great strengthened drive shaft for my brothers commodore after he broke his in half, pretty cheap for the quality and they got the work done in less than 24 hours too which was pretty sweet.
Edited by FrangaR33
I (and alot of other zed guys) have used Knox Driveshaft services with no issues to date.
73 Bursaria Avenue Ferntree Gully, 9758 4015. His name is Jeff, give him a call and he'll help you out. You might have to drop by his workshop to show him what you want done. His prices are good and I can't fault his workmanship.
yeah i've been using jeff for years.. i actually went and saw him the other day if he could help me out but he doesn't really do FWD driveshafts.. he said he'd reco them if i organise the parts, which i was considering but nissan dont sell any parts for driveshafts so all the gear will essentially be aftermarket - its an option if i coudl source all the gear but i rather take them to a reputable place that can do the job start to finish.
any others people?
get some drive shafts done at this joint at the moment will tell you on Wednesday wat the are like
Hardy Spicer
only thing is i have an r32 gtr and they would not touch the front shaft !!!!! :mad:
Hardy Spicer
they wouldn't touch the front shaft b/w the transfer case and front diff or the front driveshafts themselves? cheers mate.
If you're looking for Northern suburbs, I found these guys really good:
Duggan's Balancing
50 Newlands Rd
Reservoir
Vic 3073
(03) 9469 4550
They built and balanced a custom shaft for me for a turbo 400 box into my truck
  • 6 years later...
Digging up an old thread, I'm looking for a driveline specialist in Melbourne.
I've always had some slack/backlash in the driveline since the manual conversion (all correct R34 parts), it 'clunks' when changing from 1st to 2nd especially.
I wouldn't mind working out whether it's the clutch/flywheel, box itself, driveshaft balance/centre bearing, or the diff.
Also looking at getting the following done:
  • Engine rear main seal
  • Input shaft seal and gasket
  • Output shaft seal
  • Spigot bush – if needed
  • Driveshaft rebalance – if needed
  • Gearbox mount
Any recommendations in inner Melbourne or the north?
    • Thanks, I'll shim that plug and hopefully it fixes it.  Yes still factory turbo for now, still have the misfire it's not as bad but still noticeable
    • I had someone check the CU, they said it was fine but it could be buggered  I was only running around 7-10 PSI on the dual stage controller, but my boost gauge is shit house and needs replacing so I'm not getting a true reading.  Then I ran from wastegate pressure as per Turbosmart but still have the same sort of issue
    • Yeah this is a thing. I've had mine setup like this for a few years now, works fine. If I dredge my memory bank, I think I had to do this after I removed my factory dash.  So you've tried it on gate pressure, I'm assuming this is the factory turbo? Did you still have misfire issues with that setup?
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
