Hey everyone, The car has been smashed along the passenger side, And yes the the motor, running gear,ecu, is still for sale, car was standard no mods what so ever, only did 64,000km.Motor is in good condition and comes with turbo.Asking $1800 motor and turbo. For further info Ring 0416067765. cheers
