Got sick of my dated headlights so I just ordered these :P
http://cgi.ebay.com.au/RAYBRIG-headlights-...=item1e5fae090a
shoulda got these ones...
I'm surprised at how many cars share the same sized unit! Like even old RX7s etc. It's good :woot:
Why's it surprise you? It's a standard ISO size that most manufacturers used for pop up headlights. RX7, MR2, Z31, 180SX, MX5, S12, Prelude(or is it integra?) all use the same.
Now I just gotta decide what globes to run. Might take the HID route (like 4300 or 6000k) or just a whiter standard globe (philips crystal vision or something).
don't put HID's into non projectors you gimp. You'll blind every kent on the road with your badly focussed beams.
I don't like the look of those ones. Have seen them on another car and not a fan of the round bit in the middle.
Yeah, I don't like HIDs.. but I want a clear white light. What are my other options?
Edited by jezza boii
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...e=STRK:MEWAX:IT
get halogen bulbs colour temp rated about 6000K. 5200K is natural sunlight, 6000K is crisp white.
Yeah, 6000k would be perfect. I had 8000ks in my old MR2 and it was a bit too blue. Suited a black car but won't look good on red.
Where do I get them? Autobarn sell Crystal Vision but I don't think they're even close to 6000k...
I'm a big fan of sleepy eye conversions on pop ups, with any of these headlamps instead of standard ones:
or
http://www.jcwhitney.com/driving-lights/p2003729.jcwx
or
http://www.automotivelightstore.com/mazdam...adlightkit.aspx
I was going to go for REV6 headlights while the US dollar was strong but they're out of stock and I didn't want to wait another month.
Oh well, the raybrigs look pretty good anyway. They're 1/4 the price too. Just gotta source the globes.
let me know what size (h2, h4 etc) and I'll hook you up with some.
want: e46 m3
that is all.
i was about to post about one of these because i was offered one but still thinking about it, they are not as quick as a gtr but very comfortable and still pretty damn quick. id take one if it had a supercharger :P . still thinking about it atm.
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
