Hey guys ive recently noticed that right under where i sit in the drivers seat, whenever in gear (manual transmission) and in hi revs (i.e. 4000rpm +) my car has this really loud sucking noise.. or as if thers a massive hole in the exhaus system and air is jus gushing out of it...
it has lost top end power as well... i got a new cat fitted today - didnt fix the problem - i can still hear it occassionally... and the guys had it on the hoist and listened through a stethoscope (sp) on every joint, gasket and bit of exhaust and couldnt find any faults... before and after the cat being fitted..
just wondering what this could be?? im under the impression the stock extractors wouldnt have anything wrong with them.. they generally dont get holes in them do they?? that is one thing they couldnt check at the time because stuff was in the road so i just said dont worry about it...
anyway if anyone has a solution/suggestion would be much appreciated!
Cheers
https://www.sau.com.au/forums/topic/311154-sucking-air/
The exhaust runs underneath the passenger side of the car and for the record if you had an exhaust leak you should be able to smell it under the car, other thing is to check to see if your extractors are cracked etc. Try checking your air intake aswell.
https://www.sau.com.au/forums/topic/311154-sucking-air/#findComment-5123140
umm yeah well when i first took it to the exhaust shop to get it all looked at.. there was black residue all around the connection of the cat etc but it didnt seem to be making any noise from that section at all when he put the stethoscope to it...
but then i got a hi-flow cat in that same day so everything was taken off and tightened again so im pretty sure it isnt the flange or around the cat area... and it was done at a reputable exhaust shop with a high rep.
and nah i havent looked for holes in the floor.. but i will do never thought of that since i did get it converted to a manual a month or so ago and some modifications were done to fit my clutch pedal, i believe its only started doing it after all this work was done...
but anyway.. its going down this arvo to get looked at hopefully and i'll get all of these things checked out but yeah im still leanin toward my extractors now... i have been wanting a set from DKNE so maybe here's my excuse :)
cheers
Edited by noely1
https://www.sau.com.au/forums/topic/311154-sucking-air/#findComment-5126220
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
