nothing is for freee brothaa!!! even the water u drink, someone is paying for it...
Nah, I get my water for free too. Water tank bro!
Seriously though, you're spot on Adis. Nothing is free anymore. Not even women :P
You paid for the water tank though...every litre you catch may cost less and less as time goes on but it still cost you :P
And you're right about women. I realised the other day that renting a $100 motel room for a one nighter with a girl you just met isn't so different from prostitution - much the same expense and outcome.
You paid for the water tank though...every litre you catch may cost less and less as time goes on but it still cost you :)
I still prefer the hotel room. At least your paying for hotel and place to sleep on. When you pay the girl, your actually paying for her box. That i dont like to pay for :)
You gotta give the man the credit for having the courage to ask for it for "free." Love the sub subject line. lol
I think a mate of mine has one. I'll ask him and get back to you.
That would be awesome mate : )
  • 3 weeks later...
