My car is running an RB20DET-R redtop ECCS.
It is stock with all the -R bits (tubular manifold, TO4, specific ECU, etc)
Driving down the freeway and it dropped a couple of cylinders, no mechanical noises, and got a ride home on a tilt tray.
1st tried swapping the crank angle sensor, no change.
next swapped the igniter, no change.
next started unplugging coil packs.
The engine is running on cylinders 2,4,and 6.
1,3, and 5 are dead.
Any ideas anyone?
I've got plenty of coil packs, plugs, 3 igniters, 4 crank angle sensors, but it seemed a bit strange 1,3,5 out and 2,4,6, in.
Every 2nd cylinder out
Need help.
Hooks
Any ideas anyone?
Need help.
Hooks
hey man.
just so you know in general when coilpacks go the car still idles on 6cylinders its when under load it will normally start detonating and misfiring dropping cylinders etc
on one of my past engines was only running on 5 cylinders changed coilpacks ignitor crank angle sensor etc.. none of them were a problem so decided to do a compression test tells all tales took the spark plug out of cylinder 6 to find the end broken off run a compression test no compression on 6cylinder sounded like a hotted up subaru and a gtr with the old foot down all cylinders make some compression under full load anyways couple weeks later after some text book thrashing pulled it out and to pieces that bit of spark plug took a nice chunk out of an exhaust valve
anyways advice for you
- check coil and injector loom replace if necessary
- remove spark plugs check for missing bits
- run a compression test these engines originally came out with 180psi per cylinder. yours will more than likely have less if all cylinders are even or within 10 percent of the highest reading cylinder algud otherwise some problems with valve seals, piston rings or head gasket depending!!!
- also check near the fuse box and all earths on the vehicle
- find another standard ecu
- get it on the diognostic tester local mechanical shop
- use the red and green lights on the ecu to manually check for fault codes if possible on this model
- look for hole in engine lol
anyways if all this doesnt work or you would like some furthur information feel free to ask
I did the screwdriver to ear thing on the injectors and they are all firing
(I pretty much guessed that anyway because of the unburnt fuel coming out the rear)
I tested all the leads with a multimeter and all are good including earths.
So I tried a coilpack and plug on each cylinder. No spark 1, 3, and 5.
It's got to be between the igniter and this guy
Actually, I'm starting to think that it may be an earth problem, but whoever did the GTS-R engine swap needs their arse kicked.
When I took the kick panel off, the ECU just fell out. It wasn't bolted in, just floating around behind there. :D
Hooks
have you had any luck with this?
im having this EXACT same problem with my RB25 but im running a powerfc
cylinders 1,3 and 5 are dead.....
we're fearing it might be the ecu since the ignitors are built into my coil packs
it's definately getting fuel since i pretty much had a huge puddle of fuel on the ground after testing
  • 3 weeks later...
Made another discovery.
That looks to me like a removeable Eprom.
So It's definitely been fiddled with at some stage.
At the moment I am leaning towards the ecu being cactus.
It would be strange to have 1,3, and 5 out from the wiring.
I have another red cam cover ECCS ecu coming next week so I'll plug that in and start her up.
3 cylinders:- it's the wiring.
6 cylinders:- it's the ecu.
I'll post the results.
Lucky this car is my hobby car and not the everyday.
Hooks
Actually think I may have found the problem
Looks to me like the board has seen a bit of heat, bit hard to see here....
Here it is a little closer
And this is the culprit on the other side
And with the retainer plate removed
I don't know if it can be fixed, but I'll be making enquiries before it ends up here
Hooks
  • 9 months later...
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
