Hi all. When I was driving around yesterday in the hot weather there was this pinging/rattling type noise coming from the motor when I was flooring it. Its never really done this before and I was wondering is this what "knocking" is? Is this caused by hot weather? I have an SAFCII but the knock has always remained on 0 which leads me to think I have not wired this part correctly.
Also, my brakes seem to be wearing thin. What is the part number for just the standard run of the mill brake pads or where can i get them from.
Thanks all
Andrew
https://www.sau.com.au/forums/topic/31190-hot-weather/
Without going for a drive with you its hard to say 100%, but I'd be pretty sure the engines detonating. Its sounds like marbles rattling around or a loose screw rattling around. I would say with the extra heat, the safc2 leaning the fuel mixture out and using a stock intercooler the car's detonating. Basic fix dont thrash the car in the heat or richen up the fuel mix.
https://www.sau.com.au/forums/topic/31190-hot-weather/#findComment-629835
yeh thats what the sound was like. I had been driving reasonably hard for a while in the heat. Guess it twas just the hot weather. The car was normal again this morning.
THis might sound stupid but detonation is knocking right?
Good place for purchasing brake pads for R33?
https://www.sau.com.au/forums/topic/31190-hot-weather/#findComment-629878
Yup - detonation = knocking... detonation is NOT your friend. It is not a GOOD THING (*TM). If you hear this noise you should stop accelerating immediately. Detonation causes all sorts of problems, to mention a few - blown plugs, broken ring lands, melted pistons, burned out exhaust valves etc....
Brakes pads for an R33 - talk to Perth Brake Parts. Use Bendix Ultimate - nothing less or you will be dissapointed.
This has been a community announcement fuelled by red wine - not to say that the information is inaccurate, cause I know through experience on both counts that I'm correct! I hope it has been helpful. :D
https://www.sau.com.au/forums/topic/31190-hot-weather/#findComment-629909
Hi Andrew, I was sure we hooked up the knock sensor correctly, but I guess we never checked to see if there was any output. Definately sounds like knocking, most likely cause by heat soak into the intercooler, with the intake temps rising causing the pinging.
https://www.sau.com.au/forums/topic/31190-hot-weather/#findComment-630234
Bendix ultimate $70  :(
Woah! Where are you getting them at that price? Maybe they're cheaper for an R31? 1st set I bought were round $120 from Perth Brake Parts. Second set I got for a shade under $100 through a mate's work account at Coventrys.
BTW - just put on a set of DBA slotted rotors. Made a HUGE difference! :)
https://www.sau.com.au/forums/topic/31190-hot-weather/#findComment-632368
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
