I copped a minor defect a few weeks ago for been a little bit to low. I also got reported to the epa at the same time(boost tap). So in need of a stock r33 exhaust and cat.
The exhaust should hang high enough to clear the car of been to low and pass the epa.
If you have these parts and I could borrow them please let me know asap. Im located in rowville but will come to you.
Cheers, Aaron
https://www.sau.com.au/forums/topic/311946-need-to-borrow-stock-r33-exhaust/
I only got a minor for the hight and no fine. I keep the car looking mainly stock apart from Bilsteins and wheels.
As for EPA Im going to fit a standard exhaust and cat. Just wondering if the front mount will effect this? I know it only cools the air but this would change things from standard therfore causing a possible issue or not?
thats why you get them to leave a reasonable deposit, which they wont get back if the part is damaged.
Deposit? Im not a business.
I thought certain people would actually appreciate the fact that im helping them out and that was enough of a "deposit" but no, certain people dont give a crap, so why should i? Its good to be nice, but ill be nice to people that are worth it...such as friends, and frriends of friends... good enough from me.
well i offered him to borrow mine and to give me a deposit because what if i dont get my stock exhaust back? , im not saying his gona steal it but i was just being nice i will give him his money back.. just incase something happends. Anyway im here to help people out.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
