i want his front bar. (no disrespect)
;) sorry, couldn't help laughing at that one!
I know if I died, I rather die in my car than anywhere else. It's my baby, my life.
thats kinda scary there! i can tell you, there is plenty of other positions i'd prefer to be dying in, other than sitting down holding a knob :rofl:
Well a "weapon" can be anything, from a flower to a pencil but like anything, its how you use it that matters -and a car is as gentle as a kitten if you don't do silly things with it.. like speeding in the wet. Hope he wasn't a family man or anything - to see your father or husband go out like that would not be a pretty thing to live with for the rest of your life.
Thats a rather thoughtless comment?
What about the person who stumbles across your body, most likely in a bad state. And has to live with those images?
Uhm... someone has to stumble over your body at some time when it dies. Seeing a dead body is always traumatic, no matter if the person has just died in a bed or they have been split into 10 pieces, a dead body is a dead body. Do you think people really think just before they are about to die "hang on, what will the person think who's going to see me".
It's just a personal thought of mine that if I was ever to die, I'd rather die doing something I love, that one main love being my car.
We all have opinions and this is just mine.
just to ad a few cents as a mate of myn works near there, and from what he gathers the guy was on the highway and droped it down to third and hit boost and lost it over into the side road to hit the tree or something similar... its also should be noted that in the gold coast bulliten there is a writer comment (this weekends edition) some guy wrote in to protect '4wd' owners saying they shouldnt be banned from city road and quote 'the cars that shoudl be banned are the hoon cars"...
no doubt he had the original car crah in mind.
i cannot post it, but i looked at it tonight.  its very bad, the driver stood no chance, he must have been flat on the boards.
interesting to note the rego number, xxx-Ixx, so i would assume that the car was only recently aquired
i will not post the full rego, it saddens me that it happened.  A reminder that wet weather and speed do not go together and driving in situations such as that should not be taken lightly.
may he rest in peace whoever he was.
my numberplate is xxx-ICR so he only had it for about 7 months at the most.
i was lucky enough to learn my lesson in a very monor ding.
i hope that every crazy driver out there learns something from this horrific crash.
speed kills.
may the namesless driver rest in peace.
Poor guy. Its Unfornate how one mistake can take your life from you in an instant.
I nearly killed myself because of something stupid I did on the road when I was 17. Can say I have learned alot since then though. I was lucky but it could have been very different I can tell you.
My condolances to his family & friends.
pic in this thread:
http://www.skylinesaustralia.com/forums/sh...ead.php?t=34021
A very sad day for the drivers family and drivers everywhere, not just us Skyliners, but all drivers should learn from this horrible tragedy!
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
