hey guys and gals
i am going to be getting bride bucket seats for my 180 and i am planing on fitting harnesses
first will it really make any difference on what brand i get like if i bought them from repco etc
how would i mount them i was thinking of replacing the 2 bolts on the rear of the seat rails and the 2 in the back seat that hold the rear seat belts with eye bolts. will that work?
also where about can buy eye bolts from
thanks
Gordon
https://www.sau.com.au/forums/topic/312200-4-point-harnesses/
if ur car is driven oon the street make sure u get adr approved harnesses, regarding mounting, use the eye bolts, 2 on the sides and dunno how u want to mount the rear straps if ur bak seat is still in place
Edited by Harry-Hotpants
car is going to be mainly used for track but it is regoed
im taking out the back seats
am i able to replace the rear bolts of the seat rails with eye bolts? or do i have to make up new holes for them?
You must make sure the eye bolts can stick out so you can get a nut and a washer on it.
Also using the rear seat bolt mounts is a no go for cams event (angle is greater than 40 degree).
On the r33 i had to drill out one of the front seat holes (rear left) as the eye bolt was bigger than the std bolt. and then on the other side i didn't use the seat mount as the r33 has a mount of the side.
is your bride seat fixback? all harness will fit as they all will be 4inch or smaller in width
Edited by Kaido_RR
^^ +1
Also, I didnt some research last month and you can use SFI rated harnesses but they are only good for 2 years.
Summit Racing in the US sells cam-lock SFI rated harnesses for significantly cheaper than can be had locally.
Fia or cams approve hardness are not a must if your not doing full on racing. Cams doesn't allow 40 degree angles but most Japanese harness say just to bolt them into the back seat, that is fine as long as you can get a nut on the eye bolt. As in the case of an accident if the eye bolt is just screw into the thread of the back seat bolt holes it may rip out.
If you can I can throw up some pics later of how I did it in my 33 to give you an ideA
that would be great if you can. i will post up a pic for the rear of my 180 when i get the chance
Here you go; also took a photo of the belt so you can see the size and comparing it to the slots in the seat
Left Side i use the mount for the seat belt
Right Side, Use the mount for the seat rail
Rear Seat Mounts
Edited by Kaido_RR
thanks for that. that is what i was thinking of doing with the 180. so on the right side did the 33 just have a nut?? on the 180 on that side is a threaded bolt sticking out and the rest is bolts for the seat rails
better of using propper mounting plates and following the instalation instructions that come with your harness
i use a willans 4" 4 point that can be converted to a 6 point and believe it is far better than the sparco 3" 3 point i used to run
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
