Hi Guys,
Just clearing parts that I have bought but no longer need
R32 GTR Intercooler - $120 (pickup only - parramatta area)
replaced with an aftermarket item, its in good condition, bottom of cooler has few small dints that has bent few fins (see pics)
GTR Coilpacks - $60 + postage
was working without problems, upgraded to splitfire with new engine, cheap insurance
R32 Gunmetal Mirrors - $100 for pair + postage
in great condition, upgraded to ganador mirrors, comes with loom, suits GTS-T as well i believe
R32 GTR Tomei Speedo cluster - $400 + postage
best looking aftermarket cluster IMHO, suits late model R32 GTR
R32 GTR Standard Speedo cluster - $50 + postage
suits late model R32 GTR, good for parts but I believe its fully functional just never needed
GTR Turbo Gasket Kit - $40 for pair + postage
bought from GCG as part of their kit but no used
GTR Carbon Fibre layered battery cover - $60 + postage
brand new never installed, would look great for show car, embossed with GTR logo
Serial consult cable (PLMS Development) - $60 + postage
no longer needed as I have Power FC
https://www.sau.com.au/forums/topic/312277-rb26-parts-for-sale/
  • 3 weeks later...
  • 4 months later...
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
