Hello,
I just installed a HDI electronic boost controller for my r32 GTST but am having issues with it.
When on boost (5k rpm) the car will cut out and make loud sounds from the exhaust. (misfire?)
The EBC was installed by an auto electrician so hopefully we can eliminate a wiring issue.
Before I installed the EBC the car was fine, boosting to correct levels.
I've attempted to change the setup back to normal. Leaving the EBC in the car but bypassing the EBC solenoid which initially fixed the problems but since has stopped working properly.
What could the issue be? Spark plugs?
I've searched the forums but can't find a matching issue to mine.
(brb flame proof suit)
https://www.sau.com.au/forums/topic/312355-ebc-boost-issues/
you havnt mentioned how much boost you were/are running.
do you have a boost gauge?
are you sure theres no adjustments on the EBC?
and that it makes exactly actuator pressure before it bleeds any air off?
my moneys on its making more boost and your going R&R or too lean @ 5k rpm
also just one of those misfires etc when you first had the EBC on, would've fouled your spark plugs, now they are struggling to fire.
so new plugs as Nismoid said, then see how ya go...
yeh thats what i was thinking, with the fouled plugs. well now it should be running stock boost cos i set it up bypassing the ebc's solenoid, when i had the ebc on the boost kept going up rapidly even tho it was on the lowest setting, it hit 14 at one stage
I also have a HDI EBC-R, i havn't had an issue with it yet. As the guys have said, more boost requires more spark etc i would change plugs and if you can't afford new coils, get some industrial grade silicone and glue them up not a total fix but will fix most probs (unless coil completely gone). Also get out on a QUIET road or more safer a dyno and get it tuned and set right, if it's boosting to 14psi when it's not ment to check all hoses at the soleniod. This was happening to me but mine hit about 16psi (Shyte), i found that one of the hoses has a slight split. If you set boost to high you may break something. (BOOM) show me the money.
my two coin
Cam
thanks mate, yeh mine hit 16 psi yesterday after i thought id fixed it :blink: although it didnt feel like it was pushing 16 psi. i got some spark plugs will put them in on sunday. only want to run 10 or 11 psi at the moment too
my two coin
Cam
spark plugs fixed the misfire, but the boost controller just doesnt control the boost, it pushes past 16 psi!
runs fine if i use the same hoses but instead of going into the solenoid i just put them back into each other like an extended version of how they are normally set up, runs 11 - 12 psi though
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
    • The rod I was moving left and right you can see looking from the passenger side floor up into the center console.  IMG_8095.mov
