I can confirm the Gibson R32 GTR will be there. Group A
http://www.vhrr.com/phillip_island.htm
Saturday & Sunday
Group A & Group C Touring Cars 5 Laps 12.10 pm
Group A & Group C Touring Cars 6 Laps 4.10 pm
PI_2010_Event_schedule_Fri_Sat_Sun.pdf
Was a great day, I know a few of the drivers and managed to get some pics of my son driving the DR30. ;)
I saw a couple of GTR's including 3 R35's, but no Sau stickers. Who else made the trek down?
Awesome photos.. especially the DR30.. didn't realise that was floating around still :(.
It was locked away since its last race, Hadn't been started in nearly 20 years apparently.
Still had a lot of the original race parts like asbestos brake pads, you cant get closer to original race spec than that.
Thats correct. at least now we can see that the GIO car is the hands of a very good steerer. though im not sure what happend in the last race on sunday. he bogged down off the line, then miss shifted going from 1st to 2nd, then i think he had an off around the southern loop because when he came back into view around the back toward the hairpin, he was dead last!
it was awesome watching Terry carve his way through the field in the last race! he started at the back because he had a fuel pick up issue in the morning race (of which he was dominating!). in just six laps he managed to get from the back, up to 4th place (from memory).
In the Friday qualifying session Terry clocked a 1:44.9819! thats one for track guys who are going to phillip island in april for the wrx club day to think about... :blink:
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
