hi guys,
i did a search & couldnt find what i was looking for - as of yesterday my knock has increased as i noticed this in 3rd gear when i got to 6500rpm @ 24psi, read 70+.
when i reduce the boost level to approx 20psi the knock drops to 40 (as per pfc) & even lower boost showed 25knock.
my tuner will check this out for me but in the meantime i would like to do a check over so i dont waste his time...paul (mr swiper) was suggested i blow out the loom connectors with an air compressor as water may have entered the connectors when i washed the engine bay last week & also to check that the spark plugs all look the same (maybe a plug has failed?)
is there anything else i should check OR has anyone else experienced high knock due to something rattling/loose in the engine bay? i dont want to feel like a d1ck with my tuner if something else is causing this bizarre reading...
thanks.
marko
https://www.sau.com.au/forums/topic/312402-knock-level-increasehmmm/
  • Replies 66
Possible that you have picked up a bad batch of fuel. If nothing else has changed its weird that it will suddenly change.
I would have it looked at asap.
this is what i 1st thought - i ran the car basically dry then refilled at another bp servo (98 ultimate) & same thing.
It'll probably just be a cell that is slightly in need of attention.
Nothing major
yeah i had a squize at your pfc faq...you are probably right.
i have dropped the boost level anyway, better to be safe than sorry
Nothing major
+1
Yes indeedy, i had a knock reading of 120 randomly one day doing about 200kph, this was after consistantly never reading over 20 so probs like R31Nismoid said just a cell need a little love :P
Cheers,
Mitch.
or coils if the tune is good
If it were coils I would probably feel the loss in power in higher revs? Although this also crossed my mind
Would a faulty coil cause this symptom, I don't think so as the symptom would be hesitation
I will pull out the plugs tonight and if they look the same then off I go to my tuner
there wouldnt be any loss of power i would think it may just have a little unoticable missfire that would show up as knock. Happened to me.
But to be honest it sounds like your tune as your knock levels went down when you put loss power down.
tuned in summer? temps dropped up there recently? cold night maybe... other than that its probably as Ash suggested if you have already ruled out fuel
It was tuned on a 33deg day, the problem appeared on a 18deg day...could a drop in temp cause it?
Yes, most certainly.
As everyone has said, more than likely just a cell or two that need minor attention.
I think you need to buy a stress ball or something, a minor one-off knock is hardly anything to get excited about. :blush:
Take it back to the tuner, get it fixed. Should take less than 30mins. Drive it sensibly until then... easy as pie!
u might be right here - ji ust pulled out the plugs & no.4 plug is a lot blacker than the others...when i look at the coil pack for this plug it seems that the black lead tip on it is shorter than the others
paul - you are a legend mate, i think once again u are right - you freak!
i spoke jim @ crd & he explained that the coil pack was mis-firing with the pitted coil pack lead tip which is why the plug was black & this causes all sorts of things i.e. spark over which makes noise, even possible pinging.
i haven't test driven it yet but i'd say it is fixed :D im almost ready to put my head on the chopping block if its not rectified
i will report here once ive take it for a wrap on a long straight, 3rd gear under load
worse case i may need to buy a set of splitfire coilpacks
:D
  • 3 weeks later...
hi guys,
last night i took my car for a drive with new my splitfire coil packs & it is still knocking high so ive left a msg for my tuner to look at my car. i was hoping the coil packs would have solved it but anyway...the joy of modded cars!
2nd gear showed 34 peak knock, 3rd gear showed 66 peak knock.
i then cruised below 3krpm in 4th gear @ 60kmh - when i reset the peak knock on my pfc hand controller it immediately shows above 20 peak knock & as high as 25 peak knock (i did this back2back test a no. of times & got the same result every time). HOW is this possible on such low revs??? i think my knock sensors are not reading correctly, either they may might need replacing as ive been told they can fail OR maybe 1 of them has become lose over time, i luv playing the guessing game (reminds me of an ex-girlfriend)
if the problem was just a cell that needs attention as suggested in my above posts, would i still have the same results considering the circumstances i.e. low revs, high knock?
20 on the knock is no issue. Just driving around mine i think sits around 10-20.
There is always going to be some noise picked up, the fuel is combusting after all.
You only really need to worry about knock when it gets over 30-35. Anything below that is largely irrelevant.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
