i can understand both sides, i.e:
1. ash with more O2 = leaner & subsequent higher boost (does make logical sense)
2. nsnpwr that higher air temp will cause pinging (i have experienced this in the past)
1. The potential increase in boost from the cold dense air is what causes mixtures to lean out not the fact the air is cold/dense.
  • Replies 66
in this case it could be a combination of a cell with high advance hot weather and maybe not the finest fuel,all speculation till you, retard the timming on the hand controller and give it a blast,if the det goes away,its likely the det was not erroneous and somthing needs fairly prompt attention,700 bhp is a fair few ponies and the thing is always going to want to det at that power
How is the boost increasing with cold dense air?
Do you doubt that this actually happens?.....
I do not know and will not pretend to know the physics of it but the most logical comparison I can make is a big laggy turbo equipped car using NOS on the start line to bring the turbo on boost...clearly there is a link between a cold, dense intake charge and the way a turbo responds to it.
Heres a quick Google search for you-
'overboost in cold air'
And some comments of various experiences in relation to cold air and effects on boost levels...
The weather is getting colder here in Cincinnati. I've noticed by hitting the peak button on my boost gauge I occasionally hit 17.5 psi. The car is stock, running Stage1 MickeyD tune. In warmer weather the car hits about 15.5-16 psi.
With absolutely no boost controller your boost pressure will vary with ambient temps too, as will how quickly it can build boost.
I have experienced the same variance with climate changes on multiple other cars with various turbos. I've had a few turbo cars.
Edited by NSNPWR
cold (therefore dense) air means for the same airflow you get more oxygen as the molecules are less excited (more packed into the same space)... which can take you into areas of your mapping not previously seen when it was tuned... which can lead to some cells needing correction... its not a big deal but is very common with cars tuned during the day in summer and then thrashed at night in colder weather
What NickR33 wrote makes perfect sense aswell and corrects some of what I was actually trying to say.
This is why most tuners will leave some extra fuel in the map to allow for these sorts of variables...unless youre running mega $$$ Motec or similar ECUs which may have the ability to auto correct...?
Edited by NSNPWR
No, it actually says you are wrong when you say colder temps could not/should not affect. Seems now though you've started the backpedalling as more and more people post up as such.
Fact is colder air temps can without question have an effect which is what many people have now been telling you.
However when they produce their own experiences - you call them an idiot.
Top work champ.
Well, seems the man can never be wrong and when a few people disagree with something he says...in come the Vic Club members...lol.
I know I'm not wrong on this. I've seen it on my own car as you'll see below, and on others cars.
One of my closest friends is also a well respected tuner and we've had lengthy discussions on various issues over the years as generally he's on the mountain runs with me in his own cars.
However, what you are saying is that colder air temps should not pose a problem, factually that is incorrect and you are unwilling to be informed as such for whatever reason.
For cool, dense air to induce knock the tune must have been right on the edge as it was and unless the car is making more boost from the cooler air then I do not believe it would cause lean mixtures.
Ive never heard of anyone retuning for winter or cooler conditions (maybe adjusting boost controller) but I have for hot conditions for obvious reasons.
I've had similar issues up in Olinda (Mt Dandenong) on a 8-10 degree ambient outside temp.
Boost pressure was the same, there was no spiking etc etc.
I would get a random trigger (around 60 knock on the PFC) under max load in 3rd.
It was nothing more sinister than a couple of cells that needed adjusting. No body has said anything about retuning for winter :P
Top work champ.
1 person 1 comment...If im back pedalling then where do you stand??? Your original statement was that inlet temps were not as important a factor as ignition or fuel? And now? Lets not forget what you posted to begin with...
Air temp in terms of intake temps is not as important as the amount of the airs vs timing vs fuel etc.
Cold air is inevitably denser....meaning theyre directly related and equally important...
And I called your lover an idiot because what he said made no sense.
Better make an announcement to all turbo owners...beware of cold air....your car will ping....
I stand by what I was originally saying in that cold air can create an increase in boost which can lead to a lean mixture...if youre tuner has half a brain in his head then he wont tune to 12.5:1 and the cold air shouldnt pose a problem...
Edited by NSNPWR
Assuming for a sec Marko is running good boost control - your cold air point is now high and dry (again)... as boost pressure is now out of the equation from the get go.
I'm fairly certain ole mate does have decent boost control and i read it in a previous post. (but CBFd trolling through posts to find it)
I mean come on, you don't build a 20k setup, 400rwkw and skimp on boost control now do you?
As i said, it's not as important. The issue is highlighted by the cooler air (potentially), however it is DUE to the timing/fuel etc.
If the tune didn't potentially have a wayward cell or two then the air would not be a factor in anything as there would be no PING!
We seem to have gone around in a circle.
The original statement that
Cooler denser air = less prone to det....
has changed to
So we agree that cooler air can cause detonation (even if the reasons are not agreed upon).
The fix is finding which cells are recording higher readings on the knock sensor and pulling some timing.
Can we close the thread until Marko has fixed the issue before someone pops a vein.
My God but I miss the forums sometimes. This reminds me of my youth when I used to have a 56 Chev and a big block. There would be 20 of us standng around in the Shell garage at two in the morning arguing over anything from cams to carbs or does Mickey Thompson really exist. "ALL" the factors mentioned have an impact on tuning, cold, hot, or dense air. Cold, hot or dense fuel. What pistons or cams or ignition system one uses. Every engine is different and should be tuned as such. As the engine is broken in or accumulates the K's it will need a change in it's tune, it' OK, your both right.
i run the blitz dsbc (dual solenoid) which is a very good controller
the colour display is pretty cool as well :P
Excuse me good sir, but...
you are right NSNPWR - my peak boost is higher by about 1 or 2psi in winter than it is in summer (according to my blitz controller)
:blink:
quick update guys.
spoke to my tuner this morning...his synopsis is that it could be valve train, piston slap or genuine knock due to fuel quality – he needs to go thru the motions to rectify which is booked for next week.
hope its nothing serious, my knock level is also ranging from 10 (idle) to over 60 at times at WOT, had the dyno + road tuned and conclusion was non-engine noise being picked up although I will be getting 2nd opinion
my clutch also upon engagment is noisy and i get spikes when moving car from stationary
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
