Hi team,
With due consideration I've also decided to sell my 180sx track toy.
The previous owner did the majority of work - the vehicle had been basically set up as a drag car. Anyone who has tried to convert a drag car to a circuit car can attest that quite a bit of work is required to do so - with the exception of a few pieces such as oil cooler & some more hardcore suspension this thing is ready to go.
Personally owned it for around a year & done approx 1,500 to 2,000km total driving - none of which include any time on the track!!
It has made ~330rwkw @ 23psi and run low 11s @ 129mph, currently making ~300rwkw @ 19psi (flatter boost curve for circuit - last thing it needs is more power at this stage ;)) That said, should make 350rwkw @ 25psi and I'd love to know what it'd make with bigger fuel system, E85 & 2 bar ;)
Below specifications:
Engine (SR20 built approx 10,000km ago):
- Eagle Rods
- CP pistons
- King bearings
- ARP rod bolts
- GFB underdriven crank pulley
- New oil pump + water pump
- Genuine gasket kit
- Tomei 270 deg 12.5mm procams
- Tomei solid lifters
- Tomei cam gears
- Tomei valve springs
- Tomei rocker arm stoppers
- 1mm oversized stainless valves
- ARP headstuds
- Cometic head gasket 1mm
- Ported inlet + exhaust ports
Turbo/support:
- Garrett GT3076 0.63 56T
- Turbosmart 38mm external gate
- Custom steampipe low mount 4-1 exhaust manifold
- Braided oil + water lines
- 4" intake, apexi pod
- Twin Walbro intank fuel pumps
- Malpassi fuel regulator
- Nismo 740cc injectors
- 40mm alloy radiator
- Z32 AFM
- Splitfire coilpacks
- Greddy profec B spec 2
- PowerFc
- Front mount cooler
- New CUSCO catch can
- 3" exhaust, 2 magnaflow mufflers + resonator
- Cusco 6 point cage
- Custom single plate clutch by NPC built to hold 400rwkw
- Factory flywheel and low KM late model S13 5 speed box
- 4.3 viscous LSD
- Whiteline HD adjustable sway bars
- Whiteline lock and align kit
- Strut braces front and rear
- D-project adjustable castor rods
- D-project lower arm brace
- S14 5 stud conversion
- R33 GTST front brakes, S14 rears - brand new DBA4000s all round with DS2500 pads (literally 200km old)
- KYb adjustable shocks and king springs
- S15 wheels with near new tyers (OR: R32 GTR rims with NEW Kuhmo KU36s negotiable)
Price: $16,999 negotiable.
I'll consider offers however please keep in mind that this dosen't need to sell.
Contact: Via PM or email themorgs @ hotmail.com
Located: North Sydney
Here is an in-car video under controlled conditions....
Photos:
https://www.sau.com.au/forums/topic/312722-fs-180sx-330rwkw/
  • 4 weeks later...
  • 5 weeks later...
