hey guys
im wrecking my r34 sedan im selling everything below is a list of available parts and pm or TXT me if theres anything else you need, i will see if i can get it!
front bar - $400
rear bar - $400
side guards - $150 each
rb25 de engine (95 000 KMS) - $1800
triptronic gearbox - make an offer
spoiler - $100
bonnet - $300
rear tail lights - $350 for set
4 X 19" low profile falken tyres(about 70% tread) - $170 each
front halfcut without engine (i.e railings for any smash reapairs) $ 450
if your interested in buying the full car, inc engine, all panels halfcut to repair front end then im selling it as a whole for $5000
im located in sydney, NSW 2768 message me on 0425211199 and ill get back to you asap
ill try and have pics up soon
thanks
GUYS ITS NOT LETTING ME REPLY TO PM'S BECAUSE IM NEW ON THIS SITE email me on [email protected]
Edited by SHIVNEIL91
https://www.sau.com.au/forums/topic/312999-wrecking-r34-skyline-4-door/
Do you have the interior moulded carpet?
yeah bud i have the carpet, gimme an offer and we can workout a price. just so you know you will get the quickest reply by texting me
thanks
hay mate can u put up a pic of the centre console for me i need the climate control panel but i think it is different in the 4 doors also i need an ashtray if u have one
cheers
julz
cheers
julz
Sold to me :ermm:
You wouldn't happen to have a 3" exhaust sitting under it you want to sell would you?
umm im pretty sure its a stock exhaust but yeah im willing to sell that. ill just double check for size tomorow pretty certain its not aftermarket but
hey guys
front bar - $400
rear bar - $400
rb25 de engine (95 000 KMS) - $2000 with triptronic gearbox
spoiler - $100
bonnet - $300
thanks
Driver's side A-pillar trim to SA 5159, and centre console armrest plastic hinge please.
Along with a handful of boot interior trim plugs, the ones that you screw out ~4mm then pull out the rest of the way.
yeahp ill get a courier quote. about that hinge im only selling the armrest as a whole unfortunately. i will reply tomorow with a quote
thanks
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
