1993 R32 GTS-4
Up for sale is my R32 GTS-4. Car has been used as a daily driver for the past year. Driven from Camden to Homebush 5 or 6 times a week. I've only ever been pulled over for a RBT once while driving it, and had no problems getting through.
Reason for selling: Need to purchase a work ute
Engine
RB20 with 160 xxx K's.
- Oil always changed at 5000K's
3" mandrel bent exhaust (turbo back)
Pod Filter
Alternator and battery replaced at the end of last year
2-stage boost controller
Front strut bar
Exterior
HID headlights with matching LED parkers
Slotted DBA rotors and QFM performance pads front and back
18" rims
Lowered springs and shocks all 'round
New tyres on the front
Bushings recently replaced
Also had a camber adjustment and wheel alignment on all wheels
Interior
Replaced dash lights and climate control lights with white LED's
Boost gauge mounted on A-pillar
STEREO
7" JVC DVD screen (CD/DVD/MPEG)
6" Pioneer competition splits up front
6" Pioneer 4-way splits in the back
12" Kenwood 1200W sub in the boot
Factory Ford amplifier running front+back splits and a Soundstream amp running sub
Also comes with 3 aftermarket gauges (water temp, oil temp & air/fuel ratio) and a din slot mount. Was running in the car for a few months until it was replaced by the DVD screen.
A few bad points...
A few rust spots
- Around bottom of rear window
- On side skirts
- Back and bottom of rear wheel arches
Could use a paint job - Front bar has a crack in it and paint is chipped. Roof also is starting fade
Pictures
Price - $8000 for quick sale
Contact me (Tim) on 0411 580 392 to organise an inspection.
https://www.sau.com.au/forums/topic/313001-1993-r32-gts-4/
Price drop! $6500 ONO
DVD head unit removed! Replaced with a Kenwood CD/MP3/USB/Aux input head unit and 3 aftermarket gauges (fuel/air, water temp & oil temp) in a din holder.
Thought of a few more things on the car:
* 2-way pager alarm with remote start/turbo timer/auto windows up.
- Car always warmed up and cooled down after use.
* Also has a bosch 040 Aftermarked fuel pump
* Gearbox was rebuilt before I purchased the car
New pictures up tonight!
https://www.sau.com.au/forums/topic/313001-1993-r32-gts-4/#findComment-5178255
  • 4 weeks later...
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
    • Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
