I have just searched and read up on fuel pump upgrades to suit, but not really discovered if a standard GTR pump (R34 to be exact) will suit 300-330awkw??
The only two options it seems is the expensive Nismo replacement, or the 044 that requires modification of the cradle and various fittings. Would like to know if the standard item is up to the task to avoid uneccessary mods. Anyone done it??
https://www.sau.com.au/forums/topic/313060-fuel-pump-300kw/
Yeah that is the right approach for sure, but the Nismo item is $500+, and the bosch is cheap but requires some hacking, CAN be noisey, surge, etc.
Just thought if the 34 item is a decent one to hold to it.
Installation of a bosch pump is hardly rocket science mate :ermm:
It is a very easy job, 30mins should easily see it done.
Installed correctly there should be little noise and certainly no surging.
https://www.sau.com.au/forums/topic/313060-fuel-pump-300kw/#findComment-5145735
theres also the walbro pump at around $160-180 which from my understanding requires no modification and flows the same as the 040
No where near the same mate.
A pump over HALF the size of another logically could not do that.
Numbers below (thread on this just last week)
Bosch pumps are not noisy at all when installed correctly, and the performance between the two is not the same. You only really need to put them side by side to see why, but here are some facts all the same:
Below figures are with 13.5v pump supply.
Bosch 044 pump is 330 litres per hour and supports 730 bhp at 73.5 PSI (0 580 254 044)
Walbro 255 "high pressure" is 56 gallons/211 litres per hour at 70 PSI (GSS340)
Speaks for itself. An 044 intank fitting I find is just as easy as the walbro, I have done both.
https://www.sau.com.au/forums/topic/313060-fuel-pump-300kw/#findComment-5145875
Ok my arm is twisted, 044 it is. Thanks guys.
I wasn't saying that it will surge or be noisey for sure, i mentioned CAN be in first post based on some feedback others had posted.
BTW, i had a walbro with rewired power source in my old mid 11sec GSR for nearly 5yrs and it never missed a beat. Granted it was noisey as all fark, especially after a long drive!!
https://www.sau.com.au/forums/topic/313060-fuel-pump-300kw/#findComment-5146681
The Nismo \ Tomie is about $380. It comes on its own bracket, and has its own sock and plug. 285lph at 75psi.
You simply pull the old pump out, and drop the new one on its bracket in. Fits like factory. You can feel the sock press up against the bottom of the tank.
My nismo is completely silent too.
Worth the extra $$$ IMO.
https://www.sau.com.au/forums/topic/313060-fuel-pump-300kw/#findComment-5147499
Where in the world could you get it for that price??
https://www.sau.com.au/forums/topic/313060-fuel-pump-300kw/#findComment-5148174
FACEPALM!!!
He wrote about a 040 compared with a Walbro 255l/hr HP which have similar flow rates, you changed it somehow to comparing it with a 044...
Then you talk about it being half the size and not being able to flow similar because of physical size... NEWS FLASH: A 040 is also the same size of a 044, does this mean that they can only flow similar volumes?!?
Time to delete the internets, it's already filled with enough heros with bad advice :(
To the OP... there is nothing wrong with a Walbro GSS-342 for your predicted power. They are cheap and will flow enough, are very reliable, easy to install and are a lot less noisey than a Bosch
Edited by Cerbera
https://www.sau.com.au/forums/topic/313060-fuel-pump-300kw/#findComment-5148736
^ Nice story that.
So anyway, what was that about facepalms?
https://www.sau.com.au/forums/topic/313060-fuel-pump-300kw/#findComment-5148799
Are you really that stupid?!?
Edited by Cerbera
https://www.sau.com.au/forums/topic/313060-fuel-pump-300kw/#findComment-5149183
i have the same pump and sentiments
https://www.sau.com.au/forums/topic/313060-fuel-pump-300kw/#findComment-5149259
So what does the actual size of the pump have to do with it.
Yes the 040 and 044s are twice the size of a walbro but isnt the walbro the same size as a stock pump.
So i guess the walbros flow the same as a stock pump based on that theory.
having said all that the walbro pump will flow your power figure easily.
Yeah they may not flow the same as an 044 but they fit a hell of better into the standard cradle and are barely noticable noise wise.
https://www.sau.com.au/forums/topic/313060-fuel-pump-300kw/#findComment-5149264
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
