Hey Rod,
I don't have a RHS clear/yellow indicator. Only have complete yellow at the moment. The LHS I have clear/yellow. So let me know prob not what you're after.
Kails
GTR Guards SOLD
Nah was after RHS clear/yellow mate all sweet cheers anyway
  • Replies 77
Hi, I am new on here and I am interested in the Air Vent unit in the middle of the dash. I can see from the pic that yours is broken, but that doesn't matter. I hope to build one up using other bits as well.
If you still have it, please PM me a price and payment details.
Thanks
Thanks
Hey welcome to the site. The dash is now sold so I no longer have the vent to pull out to sell to you. Chase them up from Nissan if you want a new one $110 and worth every cent, getting to this age they are usually pretty brittle and tend to break real easy.
Kails
Kails
Thanks for the reply and the info.
hey mate im after rocker cover fitting that only has the one outlet on it and postage to 4510 if you got it?
Sorry mate don't have
hi, im lazy to look through the pages
gearbox .. that ok ?
also after complete clutch setup, brake pedal ect ect... - converting my auto to a manual.
Also, where abouts are you
Ta
LOL no worries, gearbox is sold.
I have the complete pedal set up, pm me if your chasing anything else.
Kails
hey mate, interested in dash if you still have it, will be in caboolture from the 4th to the 7th june, does it come with the cluster surround with the windscreen wiper controls etc as well, send us a pm if you still have it,
cheers
brenton
cheers
brenton
Sorry Brenton dash is sold buddy.
Cheers
Kails
  • 3 months later...
  • 3 weeks later...
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
