Hey guys,
I did a quick search but couldn't really find anything that detailed what needs to be done to fit GTR bov's to my R34 GTT engine.
From what i understand, GTR's use a twin bov system, which means i would need to get some custom piping done. Basically i just wanted to know if anyone has done this before and what was involved, or if not, if someone knows what exactly would need to be done to fit them?
Cheers,
Martin
https://www.sau.com.au/forums/topic/313379-gtr-bov-on-rb25det-neo/
Oh, really? I thought they needed the twin setup to work properly? Although to be honest i don't understand why...
So you can just use one and they fit straight on to where the RB25 one was? Still sound the same as they do on a GTR? Sound isn't important, i just think they sound awesome, so if they sound the same then thats a bonus :blink:
the hose can be "made" to fit..
needs more lube and pushing
Are we still talking about the bov? :blink:
Lol, thanks guys, so i can use a single GTR bov and it is a straight bolt on replacement for the RB25 one, no modification needed?
What diameter piping does the GTR bov use compared to the RB25 bov, do you know? Don't have the new engine yet, so can't go measure for myself :)
  • 1 month later...
Hey guys,
Just wondering if running a single GTR bov will produce the same sound as running the twin set up? I just absolutely love the sound of the GTR bov's, but if it's not gonna sound the same with a single bov then i want to try and get two working...
This is the sound i am after:
that 2nd youtube video is great but they arent stock bovs. the stock ones wont give flutter.
I've been told that's not actually flutter, it's the turbulence created by the air flowing from the two bov's into the single return pipe. My mates GTR sounds exactly like this and the bovs are definitely stock on his car
Edited by Hanaldo
GTR BOV's will "teeter" off each other etc, however one will cleraly not do that on its own.
This is what a single will sound like if the BOV can't quite pas all the air (this was a single on mine, it was ok, tiny flutter)
Ok but that still sounds quite similar to the twin setup. I'm not really after the flutter effect, just the sound of the bov. Does your bov sound like that all the time, or just under heavy load?
Say i wanted to install the twin setup on my car, what would need to be done? Is it possible? How would it differ to the single setup?
Hi Guys, sorry to hijack the thread but are you using GTR bovs on RB25DET's just for noise or is there another purpose?
Will the standard RB25DET one handle 300rwkw?
MOST people don't use them just for the noise, rather the fact that they are a very very good bov and can handle a lot of boost. I personally love the sound of them, i think they are the best sounding bov you can get. So i'm going for the upgrade, but really want the sound as well seeing as they sound so good.
Whats wrong with your GTT bov? When does it max out power wise?
Honestly i wouldn't know, engine will only be going in next week sometime :P
Stock GTT bov would be more than capable for me at first, i will only be running 12psi when i first get it back. But once i get the new turbo i will be running 18psi+, so i would like the GTR bov to have the peace of mind handling that boost.
If you're not after the sound then really i wouldn't worry about upgrading unless you are having problems with your bov.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
