I still have the following parts for an R32 GTSt and it must go!
Front guards (RH & LH sides, white paint) good cond. $460 now $100 each
L/H Front Guard *SOLD*
Front blinkers (RH & LH sides) ok cond. $230 now $50 each
L/H side Front Blinker *SOLD*
R32 GT-R sideskirt (L/H side only) full nismo three peice set $140
R32 GT-R stock cam gears $100 for the lot
I will further parts available very soon i.e. stock turbos, injectors, fuel pump etc...
P.S. Will soon have digital pictures available for the above just be patient, thanks.
https://www.sau.com.au/forums/topic/31350-r32-gts-t-gt-r-parts/
interested in front guards, front bumper if in good cond. rear lights too.
pics would be great let me know what else you got coz i might be after a few spares.
pm me with pics and whatever else you are selling that you havnt mentioned
cheers
Like to chek out those indicators.
are they the clear ones or are they all orange?
Hi, I will be posting pictures of all the things I'm selling this Monday. Unfortunately I do not have clear indicators only organge ones but are in very good cond.
SinisterR32, I only have the front guards available as the front bumper I had broke.
Thanks AS.
Ok I have some pictures available now and will have some more pics to come throughout the week.
Thanks AS.
PS. Could everyone please read the thread carefully as I am not selling GT-R front guards nor an R32 GT-R bonnet but GTS-T front guards. I do appologise for any inconvenience taken.
Cheers AS.
Pics of GTS-T guards now available.
  • 4 months later...
Hey Ants,
How are you going mate? If you still have the front guards for an R32 GTS-T I'll take them both.
You can call/SMS me on 0413 980 100, email me at [email protected] if that's cool.
Thanks for your time,
Scott King.
Hi Ants,
Might be interested in the blinkers as well, are they the headlight blinkers of the guard blinkers?
Thanks again.
Hey Ants,
Scott King.
Yes I still have all the above items for sale at same price.
I have PM you.
Hi Ants,
Thanks again.
Just for the record..
anyone who is interested in purchasing these guards.
I have the same ones in gunmetal grey.
however my skyline is white, so if the buyer doesnt own a white 32
and is going to get the guards resprayed, please let me know
as i would be interested in a swap
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
