Just spent a good few hours reading over and over this thread, the more I was reading the more I was getting gd up for my car to finish, okay for the last year and half I've been building my full house rb26 in my r32 Gtr
Specs are-
Bottom end-
JE Forged pistons
Manley con rods
Arp head/main studs
Cometic metal head gasket
Tomei oversized oil pump
Jun oil collar attached to my crank
Black full honed, blue printed etc
Acl bearings
Tomei oil restrictor
Ross harmonic balancer
Racepace extended 9l sump
Head-
Tomei 270deg 10.80mm lift Procams
Tomei type c valve springs
Tomei solid lifters
Tomei valve guides
Nitto head oil return
N1 water pump
Nismo thermostat/housing
Head all freshened up and machined to use aftermarket gear
Fuel setup -
Bosch 2000cc injectors
Pro flow twin entry fuel rail
5l surge tank
2x bosch 044 fuel pumps with a sard 280 internal pump
Turbo setup-
Precision 6466 DBB t4 twin scroll .84 purchased from gas motor sports
Custom crg twin scroll exhaust manifold
Precision 46mm external waste gate
Gearbox-
5 speed os giken gearset
Jim berry full Monty clutch
Have heaps of other bits and peices that I havnt mentioned but engine should be Goinf back in next week and keen to see what it makes on the dyno after run in tune, car will be running e85 all the time, will keep you guys updated but hoping for 500+kW
Edited by gdzlar1
  • Like 1
I've already purchased it man and got it right beside me lol, I honestly got .84 because either way the 6466 makes power but I would like the response aswell at the same
Time
Sorry forgot to mention it's got the t4 housing aswell
Exact same 6466 I put on my 25/30. Mines not really overly laggy, I couldn't imagine what the larger rear would be like though
That's insane pj 630kw is serious power lol, Anthony at mattouk said I should be able to grab anywhere from 500-550kw with this setup so let's see how we go, I was told by joe at gas motorsports this turbos wil do
It with ease I was Goinf the 1.00 ar but I want some response as it's a t4 so .84 was good for me I think
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
